m240 with R Lenses
nunnzzzz
Should be possible to focus accurately if you use a tripod and live view. Then press the focus assist button, use the thumb roller to zoom in real close and twiggle the focus till things look sharp. If that does not work, it must be something wong with your gear.
If you are using a macro lens really close up, camera shake becomes a real issue, not so much camera shake which can be cured by using a faster shutter speed but focus distance camera shake. Focussing is so critical that breathing can easily take the image in and out of focus. Use a tripod...
The M should be better in that respect than a Visoflex with its endless shutter lag. At least one can focus by moving forward and backwards in handheld macro and hope to catch the right moment in Live View/EVF
This is NOT a viable solution for using R lenses.
I disagree.
Its an option, which is welcome. Is it perfect? No...but I do appreciate the option.
I am loving the 100mm macro on the M...no problems focusing, other than the delay associated with live view.
The Leica adapter is not available. Im using a cheap $40 Fotodiox adapter until my Leica arrives.. The brand adapter is irrelevant though, it has no affect on optics.
The Leica adapter will pull up the menus, I dont think the 100mm is included anyway so I just shot as is. Some have posted that using the old leica adapter and manually coding it will bring up the menus.
You don't mention in any of your posts whether or not you're using a tripod. If not... try one. It will solve your problem. When hand holding and shooting macro even the slightest camera movement will result in unsharp images. Hookeye hit the nail on the head with his earlier piece of advice.
For slow deliberate working it is a brilliant solution. I am using various R and Visoflex lenses. It is a whole different world to the vague focusing though a Visoflex. Focus peaking is work in progress. It works well with high contrast lenses and high contrast edges but needs to be made more selectable. On the older Telyt lenses and even on the very highly regarded 80-200/f4 Vario Elmar, focus peaking is pretty hard to spot. On my Hartblei 80mm Tilt/Shift Super Rotator, which is based on an old Pentacon 6 medium format lens, focus peaking is non existent. The inability to move the focus patch is irritating and a serious omission. On the other hand, on my 28-85 Zeiss Contax Vario Sonnar, a very high contrast lens, focus peaking is relatively easy to see. The balance with these big heavy lenses on the M240 leaves quite a bit to be desired. Maybe it will be better when the MF grip arrives but that is going to make the zoom button even more difficult to hit. It is not always easy to hit focusing quickly and with the camera in balance. Nothing like as easy as with a good SLR, split image and micro-prisms. So not a perfect solution but not at all bad. After all, there are no SLR's out there which can work as a rangefinder.
Wilson
digitalfx - It would be fun if you hit the M button and got a HD video of that guy crawling around. I bet it would look pretty good.
great idea, wish I thought of that :)
It was hard enough to get him in focus as is. DOF is about 1/8" and just breathing causes focus issues.
