sveinp Posted October 8, 2012 Share #1 Posted October 8, 2012 Advertisement (gone after registration) I really need some advise here I have come across a used but mint Noct 1.0 for my M9-P and consider buying it. I am not sure if this could replace my 50 Cron in daily/overall use. I know the superb IQ from the Noct, but I also realize it's weight and rather bulky attributes. I consider keeping the Cron alongside the Noct but I don't know if I "need to", besides it is of course also a financial issue... I really enjoy the 50 Cron - IQ and handy size/weight (and as a good supplement for a 35 Cron ASPH...). Will I be satisfied with the combo Noct 50 - 35 Cron? Link to post Share on other sites More sharing options...
Advertisement Posted October 8, 2012 Posted October 8, 2012 Hi sveinp, Take a look here Summicron-M 50/2 vs Noctilux-M 50/1. I'm sure you'll find what you were looking for!
UliWer Posted October 8, 2012 Share #2 Posted October 8, 2012 I never used a Noctilux though from what I learned here you should be aware of focus shift with the former f/1-version of this lens. This means that you might have difficulties to focus exactly when you stop down appoximately until f/5.6. May be this will be no problem as you intend to use it only fully opened;). Though then you should be prepared for a rather soft lens with a lot of vignetting. Things might be easier with the Summicron. Link to post Share on other sites More sharing options...
Son of Helm Posted October 8, 2012 Share #3 Posted October 8, 2012 The 1.0 Nocti has better flare suppression than the cron, which may yield some remarcable results even on aperture 8: in high contrast situations, the scenery cry out for the Nocti. Then again, the Nocti has blurred ultimate corners, so be prepared to crop it a bit, if you use it for landscapes. If you dont expect high contrast, and aperture 2.8 and on is OK, weight cnsiderations may point to the cron. I would keep both. Link to post Share on other sites More sharing options...
a.noctilux Posted October 8, 2012 Share #4 Posted October 8, 2012 Hello, Many years of using Noctilux 1.0, I would not qualify it as universal M lens. But the photographs from this lens has something that no lens can compare. It's difficult to use wide open but possible from 2 meters and more, I have never seen focus shift. Give it a try and you can compare it with the Summicron. I use also some 50mm from Elmar (it's very anti-Noctilux in size and ease of use), Summilux, Summicron, even a Summarit and Summar. Each lens has it's own character and none is universal. Arnaud Link to post Share on other sites More sharing options...
sveinp Posted October 8, 2012 Author Share #5 Posted October 8, 2012 Thank you all for your replies! I have deceided to let the Noct passing by and stick with my 50 cron (until a mint 50 lux appears...) Link to post Share on other sites More sharing options...
tomasis7 Posted October 9, 2012 Share #6 Posted October 9, 2012 wise decision! Noctilux is most overrated lens Link to post Share on other sites More sharing options...
