Leica on Poirot
wlaidlaw
I was watching an episode of Agatha Christie's Hercule Poirot on UK ITV3 last night. It is The Case of the Missing Silver Mine Map. A policeman is following a suspect and takes some clandestine photographs of the suspect meeting some confederates. He was using what looks like a model III or IIIA, fitted with a nickel Elmar. Obviously someone had explained the use of the camera to the actor and he was focusing it properly with the focus tab and winding on after each shot with the winder knob. Sadly the photographs would not have been very much use, as he had failed to extend the lens :D
Give the producers due credit however, for trying to use a proper period camera. I doubt however if Scotland Yard would have been sufficiently advanced at that time, to have been using a Leica. They would have probably given their undercover man a 4 x 5 Speed Graflex :p
Wilson
x
Funny coincidence.... :) ; 3 days ago, in RAI TV , I watched the long pictures "La meglio gioventù" ("The best youth") , dated 2003 in which, consistent with the ages it tells about, one of the female actors (Maya Sansa) , a photographer in the picture, uses a black M6 (or M4-P ?) during a reportage in Sicily.
There is an advert on British TV at the moment, where they are using an M8. It is a very brief shot but it looks as if it does not have a lens on and still has the "Clean the sensor" pink sticker on the body cap.
It is hilarious when the continuity people make mistakes like that.
Wilson
Tony,
Perhaps the young lady holding the M8 (it might be a chrome M9-P), has drilled a tiny hole in the cap and is using it as a pinhole lens ;)
I have a body cap with a small metal plate in it as exactly that.
Wilson
:p
Wilson
May be it was a 35 Elmar and not a 50 ...
Luigi nella fiction "Commissario Nardone" il fotografo sta sera usa una M3 con il flash CEYOO.
