tobey bilek Posted July 27, 2012 Share #1 Â Posted July 27, 2012 Advertisement (gone after registration) I have the lens + E41 uv filter + Zoons clamp on shade. Â How can I put a B+W 486 on it in place of the E41 uv? Has any one solved this so the original shade can still be used? Link to post Share on other sites More sharing options...
Advertisement Posted July 27, 2012 Posted July 27, 2012 Hi tobey bilek, Take a look here Summarit with UV/IR filter. I'm sure you'll find what you were looking for!
lct Posted July 27, 2012 Share #2 Â Posted July 27, 2012 What's a Zoons clamp on shade? Link to post Share on other sites More sharing options...
01af Posted July 27, 2012 Share #3 Â Posted July 27, 2012 Unscrew UV filter, screw in B+W 486 filter. Link to post Share on other sites More sharing options...
tobey bilek Posted July 28, 2012 Author Share #4  Posted July 28, 2012 Original Leica shade  B+W does not make an E41 486 filter at least I never see one stocked Link to post Share on other sites More sharing options...
jaapv Posted July 28, 2012 Share #5 Â Posted July 28, 2012 I bought a heavy-user so cheap original yellow filter for my Summarit and replaced the glass by a 486 filter glass from a B&W filter Link to post Share on other sites More sharing options...
lct Posted July 28, 2012 Share #6 Â Posted July 28, 2012 I have no experience with the Summarit 50/1.5 but 40.5mm filters do fit according to "Hacker" here: http://www.rangefinderforum.com/forums/showpost.php?p=991308&postcount=8 For a cheap 40.5mm UV/IR filter: 40.5mm Rocolax UV-IR cut filter The latter is effective (i own one) but has no internal thread to screw a hood or another filter onto it. Link to post Share on other sites More sharing options...
brianv Posted July 28, 2012 Share #7 Â Posted July 28, 2012 Advertisement (gone after registration) Some might fit some lenses- I found that teflon tape used for plumbing fixtures was required for using the 40.5mm filter with the Summarit. Link to post Share on other sites More sharing options...
tobey bilek Posted July 30, 2012 Author Share #8 Â Posted July 30, 2012 Thank you all for the suggestions. Link to post Share on other sites More sharing options...
tobey bilek Posted July 30, 2012 Author Share #9 Â Posted July 30, 2012 I am liking the teflon tape idea best, changing the glass in a E41 second. thinking about some very thin dental floss also. Fall back is a 41-40.5 step down I found on the auction site. Â Just to test things out, I reversed a 39 mm and used a bit of thin tape. Unstable, but the shade does fit. Â A few pics inside the house confirm it has similar properties/fingerprint on digital as it had on film. What happens at 1.5 is the low frequency is retained somewhat, high frequency data is gone giving a somewhat soft focus effect. Stopped down, it looks sharp. Â I am going to try some outside pics today and post them if I get something with some artistic merit. Lack of rain has made things look bad. Link to post Share on other sites More sharing options...
