50mm lens for an M2
adamcheasley
If you are new to the world of Leica Adam it doesn't make much sense to go buying lenses by other manufacturers from day one. At least create a datum point for yourself before you start, not wake up sometime in the future wondering why you bought a Zeiss or a CV or any other substitute. They may be good lenses, but they won't satisfy the need to know.
So I suggest a newer 50mm Summicron or a 50mm Elmar M to use with your M2. By all means try others in the future if you want some (possibly expensive) fun with other makes or vintage Leica lenses, but first find out what the fuss is about.
Steve
I agree with what others have said. Just bite the bullet and get a modern 50mm Summicron.
The M2 with a 50mm Summicron will last you the rest of your life. You'll be taking full advantage of why you chose to get a Leica in the first place. And if you move on to something else there's no risk as you can easily get your money back at the time of resale.
Thanks all for the replies.
The elmar does sound appealing as it is collapsable. I will do a bit more research and see what I can find second hand.
Be it known that purchasing second hand lens is risky unless you can inspect it in-person. Best of luck, and congratulations on the M2 which was my first Leica in 1964. Enjoy!
Thank you all.
I now have a lens. The shop I went into had both a summicron and an M-Mount elmar (both 50mm, both second hand).
In the end, I went for the elmar, as the compact size was appealing, also, it was £100 cheaper than the summicron.
Now to run the first film through and await the results!
Any Leitz 50 is an good choice, that's it.
On my M2 there is an early canadian version f/1.5 5cm Summarit, M attach.
Unique fingerprint OOF and who say not sharp wide open; my sample it's sharp (... not like ASPH version!).
Important thing to find an sample with mint lenses, with no haze and no clean signs.
Amazed color pastel. Mechanics state of art.
Yes, the next Summilux will be better, but this lens surprised by the beauty and uniqueness of character.
The Noctilux has the same optical design; surely significant.
Lehitraot
Joseph mentioned the Summarit. Lovely lens.
I just wonder: what would have been on the camera when it was sold?
It would seem a 5cm rigid Summicron chrome.
My M2 permanently wears a DR Summicron of a very similar age and the combination works very well together. It looks "right" and the lens is first class quality.
Be aware that DR Summicrons do not work on M8s and M9s.
In the E. Leitz catalog #41 from 1968 the M2 had several different stock numbers, sold either body only or as a starter kit with 35 Summaron 2.8, or 50 Elmar 2.8, or rigid Summicron, or DR Summicron, or 50 Summilux. So any of these would be "correct."
The M2 I used in 68 had an Elmar 2.8 - and I still think that's a great combination. Back then the Elmar was $88!
