New Firmware 1.092 thoughts/ Read instructions
Guest guy_mancuso
  • Replies 311
  • Created
  • Last Reply
Problem with the reference pixels being corrupted by a bright light at the image border has not been fixed. They read my suggestion in pristine German and binned it. :mad:
Mark:
The problem is not the camera, but the shade is not installed on your lamp correctly :)
I would have expected that in order to see b/w in the review that you would have to set the M8 to dng + jpg.
You didn't used to have to do this. I'm not about to waste space on my card to shoot DNG+JPG when I can easily get jpegs out of Lightroom if I want them.
IMHO, I think the DNG+Jpeg workflow is a bit silly and wastes card space.
Depends, actually on how many files you shoot and how fast you want to see them / post them for proofing.
RAW + JPG lets me very quickly cull many shots, and it lets me post proofs very, very quickly. Current RAW converters, including LR, are really slow with previewing DNGs (SilkyPix is the best in this regard; it's still too slow).
More importantly, maybe, chimping feels much faster with a JPEG available. A small JPEG does seem to limit the zoom in function so perhaps people should try it with different JPEG levels.
(1) I like the new ISO and shutter speed reading in the black bar. Very useful--I dislike pressing "SET" to look up my ISO speed. (Additional feature request? White balance icon displays in the black bar, also?)
(2) The shutter does sound different. I think I like it better--it's more "clicky" when it fires but not really louder that I can notice.
(3) The battery display still doesn't come on for me after I start up the camera until I depress the shutter to the first position. (This may be a feature but it makes sense to me that the LCD fires up right away when the camera switches on without touching anything else. The first two things after switching on that I want to know are: how full is my battery? and how many shots do I have left?)
(3A) Do we have a confirmation (wasn't explicitly mentioned in the PDF) that the battery indicator has been tweaked to be more accurate?
(4) I didn't notice a real improvement in AWB, but I'm not testing side-by-side with 1.09, so I can't say much other than that.
Thanks,
Will
My cameras wake up on switching on without touching any button. It has been that way ever since I had them, also in 1.06 and 1.09.:confused: :confused:
Hi,
I have a delay before I can get pictures with the play button that I could track down to the SD card with 4G I'm using. If you look at the top display, it takes a short while before the no. changes from 0 to the no. of remaining shots. With my 4G it takes longer, my SanDisk come up after a blink. Maybe that's the effect Bill got. Bill, do you have a larger, somewhat slower SD card?
Best regards
Karl-Heinz
Shutter sound is shorter. Volume same. I prefer the new sound. Suspect the shutter is being reset quicker.
Auto WB is cooler (bluer) than previous. But, it seems to handle tungsten light much better. No filters here yet.
The black band is great. How I hated that white band. Other corrections of that ilk are for the better AFAIC.
Leica, back to the drawing board with your Auto WB. While I have someone's eye/ear let's improve the noise at higher ISOs.
"(1) I like the new ISO and shutter speed reading in the black bar. Very useful--I dislike pressing "SET" to look up my ISO speed. (Additional feature request? White balance icon displays in the black bar, also?)"
YES, I agree WB in the bar would be great. I really like having the ISO as I am forgetful sometimes --- but the lapses run to WB also and you don't know until the shot comes up all blue or red in the LCD.
AWB is still an ugly issue. This still happened with DNG:
• I shot sequently three times the same subject, using all ISO settings
• so I got 15 shots
• I changed nothin else than ISO setting leading to different shutter speed
Result:
(1) AWB is fine with ISO 160, 1250, 2500
(2) AWB with ugly blue cast with ISO 320 and 640
Sample (1) ISO 160, 1250, 2500:
Sample (2) ISO 320, 640:
Any idea why?
Best
Holger
Guest guy_mancuso
Hi,
Best regards
Karl-Heinz
Bigger cards take longer because it reads the data on the card. Also use fast cards. This is your film folks don't by cheap stuff
When I turn on my M8 with the new firmware the red light blinks once immediately and the battery and shot indicator comes on immediately after that. The buttons all work right away without touching the shutter button. I am using a transcend 4gb card. I don't notice any difference in the shutter noise but only have one camera so a comparison is difficult. I do know for sure that the camera will now wake from sleep and the first picture is normal instead of the rainbow vertical color lines. I see no change in the AWB (still horrible).
Guy, yes, of course the lamp is over exposed, but my spotmeter shows this image has levels from EV 6.3 to 18.7 so the DR is going to be blown however you expose it. If you stop down, the light is correctly exposed, but the background is hopelessly under-exposed.
In the real world, we've seen examples where the sun, car headlamps or glare off glass or water just outside the image edge bleeds through the masking around the sensor and upset the black reference for one or more half rows in the image.
I suggested a method to Leica how they could fix this in firmware but apparently not yet, if ever.
All in all, I'm a bit underwhelmed by V1.092. If this is all Leica's collective firmware development effort can produce in more than two months, we're in for a long haul...
The information displayed is for the current picture being reviewed, not the current settings of the camera. It would be nice if there was a summary line on the display when in shooting mode, but this would require the backlight to be on all the time which would kill the battery.
Guest guy_mancuso
Well your also asking a sensor to handle a 12 stop or more range too, now i am not so sure any sensor can do that. Sensors will never match what our eyes can handle . There is a point of no return too. But it still is something for them to look at no doubt. I wonder if we are expecting too much sometimes. In normal situations i have never seen this after about 11,000 shots.
It is better to recover underexposed shadows than to have overexposed highlights. The M8 seems to be better than most at shadow detail. And wouldn't a hardware fix on cameras that show this effect be more elegant than tweaking the firmware to correct something that should not be there in the first place?
Mark interesting Edmund called me about that and said the noise settled down onhis camera but that is certainly worth asking a question about. I honestly have not noticed it but that is me
It settled down, yes, because I reverted to firmware 1.09.
Edmund
Guy, this is the same recreate scenario for the problem Farrukh saw as he successively moved a lamp off the edge of the frame and I think you saw the same with the halogens in your kitchen. Nothing more.
I don't expect the camera to render detail here. The highlights are blown, obviously, but the blooming is well controlled within the image area. I do expect the bright light not to mess up the image though. It's the old problem of the pixel masking not being completely opaque.
reproduced with your kitchen halogens. Nothing more.I don't expect the sensor to render detail in the over-exposed area but I just expect it to be well controlled.
If Bill took some of his ballet shots and caught a spot light at the edge, he'd get precisely the same effect.
