Synchrony
marc_dufour
Marc,
A wonderful picture. The composition that is dominated by the rock, the subtle colors and light, the contrast between the birds and the rocks. The birds seem to glow in the light. This should catch the attention of anyone looking at it.
Paul
Paul,
Thank you so much for your kind comment.
It was early in the morning. The birds were strangely quiet. I could take several photos with some variants of a bird landing or taking off, but eventually this one with all quiet said more to me.
Jaap,
I havn't got the right point for JPG.
If I reduce the TIF file directly, it loses too much sharpness. If I add sharpess later to reduce, it's easyly oversharpened. I know I've to improve it seriously :-)
I'm glad you like the picture, beside this defect.
Start out with an image that is sharpened normally without artefacts, but decently sharp..
In Photoshop, set your crop tool to 6x4" and 300 DPI.drag to include the whole image and hit enter.
Then go to "image size" and set to 960 wide, use the default bicubic and resize.
Go to Unsharp Mask and sharpen 15%,radius 1.0,threshold 0
Go to Edit, fade sharpen 100% and in the pull down menu choose luminosity.
Save as jpeg and choose a quality setting that gives you about 300 Kb.
Btw you should convert to sRGB (not assign profile!) and 8 bits.
It sounds like a complicated procedure but it really is not. Once you have figured it out it takes about ten seconds.
For the result have a look at my "nose in the wind" shot.
http://www.l-camera-forum.com/leica-forum/nature-wildlife/216673-nose-wind.htmlqq
  • 2 weeks later...
