Collapsible M mount 90mm.
Does anyone know if you can mount this lens (Leitz Leica Elmar M 90mm f/4 Collapsible Silver 9cm/F4) on an M9? I have read on Ken Rockwell's site that it can't be mounted on the M9 (if you don't want to ruin sensor). Is this correct? Rockwell reviews the screw mount version but does this also apply to the later M mount version?
x
It can be used on M9.
To be fool proof, just put around the barrel a rubber band or something not to collapse the lens.
Arnaud
2 wrap of adhesive tape works also well just check that the lens tube comes right to the end of the M bayonet, no more than this.
There is something wrong somewhere ! You say Rockwell reviews the "screw mount version", but there is no screw mount version of the "collapsible" 9cm Elmar (except one experimental prototype in the Leica Museum).
check out Rockwell's site, you'll see. He even has pics of it.
I believe Pecole is entirely correct. Ken Rockwell mentions the collapsible M-mount and the rigid screw mount. Where did you see a collapsible screw mount on his site?
Andy
Modern replacement:
The Macro-Elmar-M 90mm collaps and nothing protrude inside the body.
This lens is amazing.
Good sharpness, nice boke, very light and with the Macro-Adapter-M take 1:3 almost macro :)
Arnaud
From the M9 manual
Leica M lenses
Essentially, most Leica M lenses can be used with the
LEICA M9. Details on the small number of exceptions
and restrictions can be found in the following notes.[...]
Important:
• Cannot be used:
– Hologon 15mm f/8
– Summicron 50mm f/2 with close up setting,
Elmar 90mm f/4 with retractable tube (manufactured
from 1954–1968)
• Can be used, but risks damaging the camera
or lens
Lenses with retractable tube can only be used with
the tube extended, i.e. their tube must never be
retracted into the LEICA M9. This is not the case
for the current Macro-Elmar-M 90mm f/4, whose
tube does not protrude into the camera body even
when retracted. It can therefore be used without
any restrictions
