maccaco Posted August 8, 2011 Share #1 Posted August 8, 2011 Advertisement (gone after registration) Hi all... Sorry to be insistent in this issue but I found an adapter 5 / 6 holes that upgrade the leica lens. Removes the back of the lens and gets it. Has anyone used one? Leica 28-90mm 6 bit code M Mount Adapter Upgrade 5 Hole | eBay Link to post Share on other sites More sharing options...
Advertisement Posted August 8, 2011 Posted August 8, 2011 Hi maccaco, Take a look here 6 bit adapter upgrade. Good idea?. I'm sure you'll find what you were looking for!
Tyranoquake Posted August 8, 2011 Share #2 Posted August 8, 2011 Don't you waste your money if you're not sure.. Simply I prefer the DIY 6 bit coding.. Only need a black marker(fine tip), coding code which easily found @ google, and 5 minutes of luck.. Link to post Share on other sites More sharing options...
ramosa Posted August 8, 2011 Share #3 Posted August 8, 2011 Never seen one of these devices. Coding versus not coding for me would be a matter of the focal length of the lens. If it's a 28mm or 35mm, I would get it coded. You could do it with a device like this, but I think I'd send a lens to a repair person to have it actually coded. For a lens over 35mm, you really won't see substantial benefits of coding, unless you really want to have the exif data transferred. (I haven't bother with my 80mm lens, but it's my only uncoded lens, so I know a photo is from this lens if there is no exif data.) Link to post Share on other sites More sharing options...
lanetomlane Posted August 11, 2011 Share #4 Posted August 11, 2011 Hi all... Sorry to be insistent in this issue but I found an adapter 5 / 6 holes that upgrade the leica lens. Removes the back of the lens and gets it. Has anyone used one? Leica 28-90mm 6 bit code M Mount Adapter Upgrade 5 Hole | eBay This looks interesting ...... thanks for posting. So far I've coded my lenses using a Dremel and Black (Matt) and White paint. I haven't yet coded my MATE as at the time I couldn't find the appropriate code for it. I just may get around to buying one to try it. ____________________ Regards, Tom Link to post Share on other sites More sharing options...
lct Posted August 11, 2011 Share #5 Posted August 11, 2011 ...I found an adapter 5 / 6 holes that upgrade the leica lens... Are you sure they sell 6-holes adapters? I see only 5 holes in your link and most of my lenses have 6 screws hence my question. Link to post Share on other sites More sharing options...
lct Posted August 11, 2011 Share #6 Posted August 11, 2011 Don't you waste your money if you're not sure.. Simply I prefer the DIY 6 bit coding.. Only need a black marker(fine tip), coding code which easily found @ google, and 5 minutes of luck.. And be prepared to do it again and again if you change often your lenses, w/o forgetting to clean out the bayonet, the 6-bit sensor and the camera mount each time. Bit of a pita for me, to the point that i bought a mini dremel and did an ugly DIY work on my little CV 21/4 P, but it works like a charm since then. Link to post Share on other sites More sharing options...
maccaco Posted August 11, 2011 Author Share #7 Posted August 11, 2011 Advertisement (gone after registration) Are you sure they sell 6-holes adapters?I see only 5 holes in your link and most of my lenses have 6 screws hence my question. Yes, there are 6 holes. When ordering you must specify the number (5 or 6) ... is indicated in the description Leica 28-90mm 6 bit code M Mount Adapter Upgrade 5 Hole | eBay Link to post Share on other sites More sharing options...
lct Posted August 11, 2011 Share #8 Posted August 11, 2011 Sorry but it is not clear at all. Hard to hit the buy-now button w/o being certain that they sell 6-holes adapters actually. I would be prepared to buy one otherwise. Link to post Share on other sites More sharing options...
maccaco Posted August 12, 2011 Author Share #9 Posted August 12, 2011 Sorry but it is not clear at all. Hard to hit the buy-now button w/o being certain that they sell 6-holes adapters actually. I would be prepared to buy one otherwise. Have return policies, so little is lost. I am considering one for my VC Ultron 28 (Ask if I can ...) Link to post Share on other sites More sharing options...
lct Posted August 12, 2011 Share #10 Posted August 12, 2011 I asked them a question about 6 holes adapters last month to no avail so far. BTW the Ultron 28/2 bayonet has four holes only if i'm not wrong. Link to post Share on other sites More sharing options...
maccaco Posted August 12, 2011 Author Share #11 Posted August 12, 2011 I asked them a question about 6 holes adapters last month to no avail so far. BTW the Ultron 28/2 bayonet has four holes only if i'm not wrong. Yes, I just saw the Ultron and 4-hole (well, playing paint! ) I'm going to wait for an answer too (maybe a vacation and will not work. I do not know) I'll tell you if they answer. Link to post Share on other sites More sharing options...
lct Posted August 12, 2011 Share #12 Posted August 12, 2011 ...I'll tell you if they answer. Ah yes thanks. Link to post Share on other sites More sharing options...
maccaco Posted August 12, 2011 Author Share #13 Posted August 12, 2011 Ah yes thanks. zhwksweden ebayer has answered the following ... "Hello, it takes 3-4 weeks to order 6 hole version adapters for 28/90 and 50/75 or 35/135. Thanks" I think that I will ask the 50-75 for my SUMMICRON 50, and see if it goes well ... Link to post Share on other sites More sharing options...
lct Posted August 12, 2011 Share #14 Posted August 12, 2011 Thank you maccaco Link to post Share on other sites More sharing options...
Bobitybob Posted August 13, 2011 Share #15 Posted August 13, 2011 You could look at Classic Cameras in London who offer a 6 bit coding service for Leica, CV and Zeiss. Not many details and a little expensive, but if done correctly may be worth the additional cost. Here's the e-mail address Leica Cameras, Summarit, Voigtlander, Zeiss, Minox Binoculars - Classic Camera Ltd UK. Link to post Share on other sites More sharing options...
maccaco Posted August 13, 2011 Author Share #16 Posted August 13, 2011 Thank you maccaco No problem!... You're welcome. I made an offer to the ebayer by 50/75 (6 holes). If I have luck in a few weeks the adapter come to my house and I'll prove it. I'll tell you then I think, and put a photo. Best regards Link to post Share on other sites More sharing options...
maccaco Posted August 13, 2011 Author Share #17 Posted August 13, 2011 You could look at Classic Cameras in London who offer a 6 bit coding service for Leica, CV and Zeiss. Not many details and a little expensive, but if done correctly may be worth the additional cost. Here's the e-mail address Leica Cameras, Summarit, Voigtlander, Zeiss, Minox Binoculars - Classic Camera Ltd UK. Thanks for the info... I also I have good references about http://www.kamera-service.info (Netherlands) and the price is very reasonable and very good communication. Link to post Share on other sites More sharing options...
lct Posted August 13, 2011 Share #18 Posted August 13, 2011 ...If I have luck in a few weeks the adapter come to my house and I'll prove it. I'll tell you then I think, and put a photo... Very kind of you thanks. Link to post Share on other sites More sharing options...
RobertJRB Posted August 14, 2011 Share #19 Posted August 14, 2011 I don't really see the big advantage of this one.., 100 dollar for a peace of metal... doesn't the official leica coding cost the same? About 100 dollars? And for the non leica lenses, coding an 28/2.8 zeiss by Will van Maanen (Holland) costed me 80 euro's. Just send the lens and have it back within a week time. Link to post Share on other sites More sharing options...
lct Posted August 14, 2011 Share #20 Posted August 14, 2011 New bayonet or old one with new notches? Matter of tastes. I prefer keeping the original one as is personally. Now remains to see how this new bayonet works actually. Link to post Share on other sites More sharing options...
