M3 VF's focal length equivalent?
philipus
Hi all
Here's a, perhaps, odd question. What is the focal length equivalent of the M3 viewfinder? Since the 50mm frame lines are smaller, I would guess the VF is a bit wider but how much?
Sorry if this is a dumb question.
Cheers
Philip
I don't know how to define the focal length of the viewfinder. Usually it's magnification is given. The M3 had the largest magnification of 0.9x, the M2 and most following M-types had 0.72x, the digital bodies M8 and M9 have 0.68x.
So the 50mm frames in the viewfinder of the M3 are the largest in any M camera. Because of this magnification the frames for 35mm lenses didn't fit in and you needed the lenses with goggles to compensate, so you could use the 50mm frame for 35mm.
Since the 35mm frame does not fit in, and there is not that much outside the 50mm frame, I would guess something like 40mm for the viewfinder edges.
Thinking of it as I am writing this, the M3 may be the best M camera to use the Summicron/Rokkor 40mm/f2.0 with, after the CL! I'll have to check it out...
Guy
...there is so little around the 50mm frame on the M3 that it is no use for framing. The frames where reduced in size when the 28 was added, so any 0.72 finder with 28 in it has a '35mm' frame which is actually more accurate for 40mm
Sorry about the split post, I hit the wrong button on my phone!
Gerry
