Filters and Contrast
gtto
Do most of you find less contrast when using UV/IR filters? At the moment ,I am not using any so I have nothing to compare it to. I have always used a UV filter as protection, on all my othecanon lenses and never thought about a contrast difference but I have read much about how another surface can cause more flare and less contrast. Opinions? Thanks gary
x
No the only significant differences i perceive are a feeling of enhanced sharpness and more or less green oversaturation in grass and foliage with UV/IR filters. Now i did not use UV filters regularly before so take what i say with a pinch of salt.
Hi
If the sun is low (soon be your fall) and you are shooting into shadow, chimp regular for iris images etc. remove filter upon artifice...
Use deeper 3rd party hood if the leica one telescopes...
Noel
I think I know a bit about postprocessing - but I know of no way to compensate completely for contrast loss due to veiling flare.
Regardless it wouldn't matter to me since I always edit in RAW.
Hi
Yes but the IR filters and sensor can do more than veiling flare with a low sun shooting into deep shade even in medium UK latitudes, even with a hooded cron...
Easy to see when you chimp, veiling flare you might miss...
Removing the filter may not help 100%
Noel
I was just responding on differences between UV/IR and UV filters here. Of course, like all filters, UV/IRs can cause flare and ghost images but we all know this don't we.
