Nippon Kogaku Leica Bayonet Mount
FiZZ
A couple of years ago I bought an M2. The camera came with a Nippon Kogaku 5cm f/2.0. I haven't been able to find any info on this particular lens. I read from an unconfirmed source that Nikon made their lenses with the Leica M mount, but I haven't been able to find any official literature from Nikon themselves. Any help would be appreciated.
Nikon made many of its rangefinder lenses in Leica thread mounts. (Rotoloni's big book gives production numbers.) These can be used on M cameras with the standard Leica adapters. Leica owned the patent on the mount at that time. I don't see how Nikon could make M mount lenses. LTM patents were negated after WWII.
I still use a 105mm f2.5 lens frequently on the M9. I'm very fond of this lens.
.......... I read from an unconfirmed source that Nikon made their lenses with the Leica M mount, but I haven't been able to find any official literature from Nikon themselves......
I don't know who or what your 'unconfirmed source' is but, there is a good reason for it to be unconfirmed......... :rolleyes:
Nikon never made lenses in Leica M mount, only in Leica Thread Mount and of course in their own Nikon RF mount (practically the same as the original Zeiss Contax RF).
If you find a Nikon RF lens that fits an M body directly, it is most certainly a Leica Thread Mount lens with an LTM to M mount adapter. This is from a source that can be confirmed many times over..... ;)
Best,
Jan
Best,
Jan
Thanks Jan. I don't see any adapter attached so I'm assuming that the mount was custom milled by the original owner.
I'm sure it would be of interest to all of us to see pictures of the lens and mount. Is that possible? Then further information could possibly be given. David
Excuse the poor quality, taken with my webcam. The front of the lens does not rotate. The distance markers are in feet, and the lens says Nippon Kogaku Japan. According to the Interwebz, that means it was made in Occupied Japan after the war, and I'm assuming that since it's in feet, it was meant for export to the US market.
To me that looks like a Nikon lens with Leica thread mount, on which there is mounted an original Leica LTM to M adapter. At least my own original adapters look exactly like this.
Andy
I thought so too, but upon closer inspection I see that the lens mount is attached directly to the body, not to another mount. The red dot that lines up the lens mount with the body bayonet is one piece, no seams.
If its an adaptor surely there would not be a red dot, unless its been glued on separatley, the adaptor has a red line on it which on all my screw lens (admitedly not Nikon) just shows beyond the lens body. A close up of the 'red dot' would help think!
Gerry
What seems conclusive to me is the U-shaped cutout near the OP's thumb in the second photo. Leica bayonet adapters had this (it engages with a lug on the back of a lens rear cap to make it easy to remove a lensless adapter from an M body) but M-mount lenses don't need it and don't have it.
I'm less sure about the ring of naked brass, though it's also something that seems to exist on all old bayonet adapters but not on M-mounts.
More photos please!
A Leica adapter is attached. You can see the U cut under the lens mount and the smaller notch at 12 o'clock. Put the lens/adapter on the M camera and unscrew the lens from the adapter. The adapter is then removed with a Leica M rear lens cap that has the three little protrusions that engage the cuts mentioned in the first sentence. (There are three rear cap types, make sure you have the one the black and grey version with the protrusions.)
Fizz, you will have accept the hard truth...... You have a Nikon lens in Leica Thread Mount, with a Leica LTM to M mount adapter attached. End of story.;)
Removal of the adapter may be as simple as described in above posts or, the original owner may have used glue for a rather permanent fit. If the lens does not unscrew from its locked position on the body, unlock the lens, turn it as when removing, and try to unscrew it in that position.
Reason for that is that, sometimes the unlock grove in the adapter may give way and slip when lots of force is applied. By unscrewing aganst the body lens mount more force can be applied, should it be needed.
I hope my instructions make sense....
Good luck,
Jan
Good luck,
Jan
No! I refuse to accept it! There has to be a deeper story to this!!! =(
Whoever attached the adapter did a damn good job. I've had the lens for two years and been trying to unscrew it and haven't been lucky. Glued on there damn good.
For those of you wondering about the performance of this lens:
I find it a bit soft wide open, but I like it because it has this smooth creamy bokeh. A bit dream like. Will be posting shots once I finish the current roll of colour 800 Portra.
Film shot here was Kodak 400CN.
To accept it or not is up to you. The fact is that you have a screw mount lens which has an "M mount" adaptor fitted to it. Leica and Voigtlander, plus some other companies made these adaptors and Giordano's advice about the "U shaped cut-out" being the clue to this being an adaptor is, in my humble opinion, totally correct. If you wish to separate the lens from the adaptor, it seems the specialised tools and expertise of a good camera repairer should be sought. It may be that the adaptor has been cross threaded or, as previously suggested, glued; or, simply, overtightened. Another possibility (though slim) is that the adaptor thread does not exactly match that of the lens. I have seen this on one occasion, but not with Leica or Voigtlander adaptors. Kind regards, David
Sometimes owners attach the adapter with Loctite thread lock, which is strong enough (due to the area of the bond) that it is permanent. Enough heat to loosen it would destroy the lens. There is no need to lock an adapter on like this, but...
Here is a Leica-made adapter removed from a lens to compare:
  • 3 weeks later...
Does anyone know where I can buy a LATER version of this lens - non close focus - with a serial number starting with the number #7 ? - Like #71xxxx or #72xxxx
Nikkor HC f2/50 JAPAN in LTM
Write me to my email please, I NEED the lens A.S.A.P. for a magazine shoot
ohh and there's NONE on ebay BTW - I have to find one OUTSIDE of there......
Tom
