Question on Leitz Elmar 50mm collapsible
BlackDE
I have just bought an old Elmar 50mm collapsible in very good condition. However, when it does not collapse all the way in, just about half way. Is this normal or have I bought a defective lens?
I appreciate your comments.
There can't be many things that could stop it collapsing.
Does it collapse when not on the camera? If not has the previous owner put a stop of some sort on the barrel, look for a band of plastic etc (some people use cable ties, but you would have spotted that).
If it won't collapse on the camera maybe its the camera, an M5 maybe, or an m4/3 body etc.
Steve
As suggested try collapsing it when it's off the camera, (which camera?).
There can't be anything stopping the lens as such, it's just a barrel, but maybe its sticking a little at some point due to dirt or whatever, so clean it and try the very lightest smear of vaseline (VERY LIGHTEST) around the barrel.
Thank you guys for your help. And please take my apollogies. I am so stupid. I tried to collapse the lens when it was still with the rear lens cap on. Like this it won't collapse. Mounted on my M3 now it collapses perfectly.
Again, sorry for this.
Cheers,
Bernhard
You know, don't you, that you should not mount the lens on the camera when the lens is collapsed?
The advice to mount the lens extended is just to accomodate people who are clumsy and can't line a lens up with the body properly. It is not essential advice unless you fall into this category :)
Steve
Steve
I appreciate this advice since I fall into this category. :) Thank you very much.
Steve
We do all fall into that category occasionally If we didn't, bridges would not need protective railings. An ounce of prevention ...
The old man from the Age Before Nearly Everything
But are railings on bridges better at protecting you than the knowledge you will die if you step over an unprotected edge? Railings are an encouragement to get right to the edge, lean over, look down, fall........ If there was more danger in peoples lives there would be more common sense to go around (an unfortunate conclusion of happy healthy and overtly safe lives in the Western world). If we need a warning that you can scratch the inside of the camera by mounting a collapsible lens its only because we have allowed ourselves to become helpless at spotting simple dangers in our actions. Today we get warnings on sharp objects not to cut ourselves despite modern medicine, in olden days cutting yourself could lead to infection and death. So who is likley to be more careful, modern man in a modern kitchen, or our great grand parents? We hand over responsibility to advisers. If people need a sign to say 'do not stand near the edge of the cliff' what is that saying about people? :D
Steve
