4season Posted June 17, 2011 Share #1 Posted June 17, 2011 Advertisement (gone after registration) Anyone experience this? With M9 set to Soft Advance, the shutter will sometimes fire a second time as I'm releasing the button. It never happens in Standard mode. Link to post Share on other sites More sharing options...
Advertisement Posted June 17, 2011 Posted June 17, 2011 Hi 4season, Take a look here Soft advance causes unwanted 2nd exposure?. I'm sure you'll find what you were looking for!
elgenper Posted June 17, 2011 Share #2 Posted June 17, 2011 Anyone experience this? With M9 set to Soft Advance, the shutter will sometimes fire a second time as I'm releasing the button. It never happens in Standard mode. Has happened once or twice, not more. There are several (8 if my binaries are ok...) combinations of soft/normal + discreet/normal + review-while-holding-button/no-review-w-h-b, and some of them can lead to unexpected effects in some cases. Find one that suits you, stay with it, and learn what might happen, and you may find a predictable behaviour. BTW, any problems of this kind are prone to be aggravated by the use of continous drive... Link to post Share on other sites More sharing options...
Hans Berkhout Posted November 24, 2015 Share #3 Posted November 24, 2015 This will happen when you press the shutter advance button all the way down. The soft release option is designed to fire the shutter on the slightest depression of the advance button. Then let go, and there will be no 2nd shutter activity. Try the same but press down all the way, and you 'll note an unintended 2nd shutter release. Hans Berkhout www.gelsilver.blogspot.ca Link to post Share on other sites More sharing options...
250swb Posted November 25, 2015 Share #4 Posted November 25, 2015 You haven't made it clear, but I expect the seriousness of this, or not, is if a second photograph is being made upon the second shutter release, otherwise it's just a noise. Steve Link to post Share on other sites More sharing options...
Hans Berkhout Posted November 25, 2015 Share #5 Posted November 25, 2015 Sir, as suggested in the title of this thread a second photograph will be taken when the soft advance etc etc hans Link to post Share on other sites More sharing options...
jaapv Posted November 26, 2015 Share #6 Posted November 26, 2015 This will happen when you press the shutter advance button all the way down. The soft release option is designed to fire the shutter on the slightest depression of the advance button. Then let go, and there will be no 2nd shutter activity. Try the same but press down all the way, and you 'll note an unintended 2nd shutter release. Hans Berkhout www.gelsilver.blogspot.ca I cannot replicate this on my M9 nor my Monochrom1. I would say it is anomalous behaviour. Link to post Share on other sites More sharing options...
Hans Berkhout Posted November 26, 2015 Share #7 Posted November 26, 2015 Advertisement (gone after registration) You may be right Jaap. I've always have my M-E advance work this way (on soft) and thought it was normal, until I discovered this (old) thread. I'm so used to it that I'll leave things alone-it may change to "normal" in the future with new firmware I suppose. Nothing is perfect. Link to post Share on other sites More sharing options...
