hydeca Posted May 17, 2011 Share #41 Posted May 17, 2011 Advertisement (gone after registration) M9 (new August 2010) - Sensor assembly replaced (damaged during cleaning using Pentax lollipop) - Shutter failure (currently undergoing repair) M6 TTL (early 2000s, second hand March 2011) - Perfect Elmarit 28 (new August 2010) - Severe back focus fault (currently in transit to Solms for inspection) Summarit 50 (new August 2010) - Perfect Summicron 50 (mid 90s, second hand March 2011) - Perfect Summarit 75 (new May 2011) Winder for M6 (new May 2011) - Haven't opened the boxes yet as overseas but expect both will be fine So mine's a mixed experience but I am REALLY pleased to see the results of the poll so far; it restores my confidence in the M9 considerably. Its really valuable information for potential buyers as well as current owners experiencing faults. I reckon it should be enough to persuade NZDavid to go ahead. Link to post Share on other sites More sharing options...
Advertisement Posted May 17, 2011 Posted May 17, 2011 Hi hydeca, Take a look here M9 reliability poll (for NZDavid) . I'm sure you'll find what you were looking for!
sydkugelmass Posted May 17, 2011 Share #42 Posted May 17, 2011 So you are using your cards in two different cameras? That is a nearly certain way to create the faults you describe - pilot, not camera error I would say. Not at all! I just use one card in one camera, always the same pair card-camera. But: It was impossible to use with the M9 three different cards of the same sort, bought in two different shops. The three different cards were then reformatted in a PC with FAT32. The scandisk program found some (small) defective areas in every card. The cards were perfectly usable both in the PC and, reformatted in the camera, with the Lumix G10. If I try to reformat the three cards in the M9, same problem reappears as said in my preceding post. Link to post Share on other sites More sharing options...
frc Posted May 17, 2011 Share #43 Posted May 17, 2011 -Mine froze when using a SanDisk Extreme Pro 8GB. -One corrupted file, left and right side of one file were of different images. ( this was on a loner before I had my own ) -On/off switch can rotate when the camera is flung into the bag ( after a quick grab for the long lens SLR, don't tell me to be more careful ) resulting in multiple pics of the inside of he bag and possible drain of the battery. Link to post Share on other sites More sharing options...
pelagia Posted May 17, 2011 Share #44 Posted May 17, 2011 + 18 months, 24500 shots Link to post Share on other sites More sharing options...
jaapv Posted May 17, 2011 Share #45 Posted May 17, 2011 Not at all! I just use one card in one camera, always the same pair card-camera. But: It was impossible to use with the M9 three different cards of the same sort, bought in two different shops. The three different cards were then reformatted in a PC with FAT32. The scandisk program found some (small) defective areas in every card. The cards were perfectly usable both in the PC and, reformatted in the camera, with the Lumix G10. If I try to reformat the three cards in the M9, same problem reappears as said in my preceding post. OK thanks for the clarification . I will not derail the thread by discussing the problem - search the forum elsewhere - there are plenty of threads on the subject which may be helpful. Link to post Share on other sites More sharing options...
MarkP Posted May 17, 2011 Author Share #46 Posted May 17, 2011 So far so good.....Jaap has this restored your faith?....but we really need many more posts. However only one in 10 who have visited the thread have responded. We really need to encourage as many M9 owners as possible to contribute. PLEASE leave comments & unrelated problems out, however tempting it may be! Once we've enough posts I'll start analysing and presenting the findings, and update them if the contributions continue. Regards to all, Mark Link to post Share on other sites More sharing options...
denoir Posted May 17, 2011 Share #47 Posted May 17, 2011 Advertisement (gone after registration) I'll give a full list including lenses. M9, 8 months -Rangefinder decalibrated out of the box. 28 Cron ASPH: + 35 Lux ASPH: + 50 Lux ASPH: + 75 Cron ASPH: -Front focusing (Trip 1 to Solms) -Broken aperture ring (Trip 2 to Solms) -Back focusing (Current status, I should send it in) 90 Cron V3 (used): + Zeiss 18/4 Distagon: + Zeiss 25/2.8 Biogon: Uneven focusing ring. Zeiss 35/2 Biogon: Wobbly focusing ring, front focusing. Zeiss 50/1.5:+ Link to post Share on other sites More sharing options...
Wowmeta Posted May 17, 2011 Share #48 Posted May 17, 2011 - 6 Months Horizontal lines in pictures Hangs by writing on SD-card Swap directly in Solms - 1 Week (the swapped M9) Horizontal lines in pictures Vertikal failure in one kompl. line of the sensor. Ding ding .... next Round with Solms CS P.S. like the M9! Link to post Share on other sites More sharing options...
hofo100 Posted May 17, 2011 Share #49 Posted May 17, 2011 + 2months, 2k pics. Regards, Holger Link to post Share on other sites More sharing options...
seacat Posted May 17, 2011 Share #50 Posted May 17, 2011 + M9 2 months - very minor sensor oil/dust spots from brand new, only found after a test shot @ f16 - blue sky. Could not be happier. +++ 50 mm Summilux - Superb lens - perfect build quality. Link to post Share on other sites More sharing options...
swamiji Posted May 17, 2011 Share #51 Posted May 17, 2011 2 M9's, one 18 months, one 7 months. No problems! Dirty sensors come with changing lenses. Memory card issue came with my M8. So these are just par for the course. I had a problem with the aperture ring on my summarit 75. Other than that, the only service any of my leica gear has had Is a 6-bit code upgrade on particular lenses. Link to post Share on other sites More sharing options...
delander † Posted May 17, 2011 Share #52 Posted May 17, 2011 + 2 M9s 18 and 16 months Jeff Link to post Share on other sites More sharing options...
xrogers Posted May 17, 2011 Share #53 Posted May 17, 2011 +, 9 months. Link to post Share on other sites More sharing options...
Garry Blagrave Posted May 17, 2011 Share #54 Posted May 17, 2011 + 4 months Link to post Share on other sites More sharing options...
theno23 Posted May 17, 2011 Share #55 Posted May 17, 2011 +18 months, 12k exposures (at least) had some minor issues under certain circumstances, but they seem to have gone away. love the camera Link to post Share on other sites More sharing options...
horosu Posted May 17, 2011 Share #56 Posted May 17, 2011 + 19 months All fine Link to post Share on other sites More sharing options...
tdtaylor Posted May 17, 2011 Share #57 Posted May 17, 2011 18 months, 12k exposures. Rangefinder focus re-calibrated out of box. NJ handled very well. Happy ever since. Link to post Share on other sites More sharing options...
ayewing Posted May 17, 2011 Share #58 Posted May 17, 2011 + (6 weeks) Link to post Share on other sites More sharing options...
dancys Posted May 17, 2011 Share #59 Posted May 17, 2011 + 19 months, 18,000 shoots Link to post Share on other sites More sharing options...
gearoido Posted May 17, 2011 Share #60 Posted May 17, 2011 14 months. No problems GaryO Link to post Share on other sites More sharing options...
