M8 + high ISO + low light shooting
sparkie
x
The M9 FAQ are very useful for M8 owners as well:
Sharpening slider.
Set for the optimum detail separation (normally between about 10 and 40), never mind that you seem to increase the noise, in conjunction with the next
I would recommend to not to use the sharpening build into the ARC and LR RAW converters, seems to me sharpening is best done as the last stage of PP and targeted at the intended use; print, web, poster or whatever.
Low Light Shooting
Choose type of lens and focal length for the subject matter and with regard to the low light properties, aspherical, low coma etc.
Set the Aperture for needed depth of field.
Set the Speed for what is needed to freeze the action or use some kind of support or monopod/tripod.
Set the ISO as high as you dare for what the intended use, again; print, web, poster or whatever. Consider if Noise reduction software is an option, Noise Ninja (On Nikon D3 just set to Auto ISO)
Not enough light, consider fill flash, or go for the full flash setup.
Incorrect. 1.Capture sharpening in raw conversion and noise reduction.
2. Creative sharpening in post-processing
3. Output sharpening is a mathematical excercise.
Trying to cram 1. and 2. in no. 3 is a virtually sure recipe for a missharpened image in the end.
Incorrect again ;). Follow the order of the sliders ( from CS5/LR3 preferably) Sharpening and noise reduction in raw conversion is a two-step process, but the two are interacting. A good read on the subject is Real World Sharpening by Schewe and Fraser. Martin Evening has some relevant parts in his books as well.
Guest Randle P. McMurphy
Rule 3: One glass of whisky will steady your hands enough to get a proper exposure.
Rule 3(2): After a bottle of whisky you dosen´t care about exposure any more. :rolleyes:
I was a real fan of Noise Ninja for years. A few months ago I used a trial version of
TOPAZ DENOISE and bought it. It has much better intuitive control than Noise Ninja and produces better results.:D
I prever the old fasioned analog way - use a tripod and don´t care about
bad resolution with high ISO - only problem ist to find a trial version of it.
Cheers
All I Can say is that CS3-5 gave me som terrible results, I investigated and found the sharpening to be the reason, all the PRO users of Adobe Photoshop I know turn off sharpening in ARC.
The order of the rulers doesnt dictate the order of the software processing, unless Adobe has rewriten the program.
I have now mostly turned to other RAW converters.
I prever the old fasioned analog way - use a tripod and don´t care about bad resolution with high ISO - only problem ist to find a trial version of it.
The trial version only has two legs and a fence post. But it can ride a bicycle.:rolleyes:
Pete.
CS3 was indeed not very good, and did give rise to one-step sharpening. But that is way in the past.
Very true, Pete. It wouldn't sound right though if I said "It's not uncommon to see ISO ratings of 102,400 now!" Because that speed is still a bit less common. :p
Incidentally, ISO 25,600 is not the cutting edge anymore; it's ISO 102,400 on the Nikon D3 now.:rolleyes: (But I understand what you're getting at.)
