Hand grip vs Thumbs Up Thing?
DKbRS
Was concerned about a hand grip's added bulk so I contemplated the purchase of a Thumbs-up ... however there I was concerned about the stress it might put on the hotshoe and about possible trouble when using the wide-angle accessory finder. Eventually I tried a Leica hand grip and was sold immediately. The added bulk is neglectible; the shape allows the fingertips to slip a tiny bit into the gap between grip and camera body; handling the camera is transformed for the better. Bought it immediately, used it ever since, and never wasted another thought on the Thumbs-up thing.
It all depends on the size/shape of the individual's hands I suppose. I have a couple of Leica handgrips and found
them uncomfortable, disliked the Thumbs-up because it blocks the hot shoe and was not quite fit for my hands either and would not be without the Thumbie now.
  • Replies 77
  • Created
  • Last Reply
The M9 does not need to be clutterred up with extraneous doodads such as the Thumbs Up or a large handgrip.
Lars, I do believe that is your opinion, and obviously works well for you. In my case, holding the naked camera in my palm, the index finger jambs into the lens and my thumb ends up half way across the screen, so I end up with it not sitting in my palm. I end up having to squeeze the camera like a pack of cards- get tiring after a while. As I stated earlier, isn't it great we have options to accommodate most of us.
OTOH, a small bump as you mentioned would probably go a long way towards improving ergonomics for many.
Also, as a note, I don't use the Thumbs Up anymore- it it easily hit and has left considerable denting on the back of the top plate.
I my case I bought a Leica bottom plate/hand-grip unit and would not be without it.
I promise you that without it I would have dropped the camera many times by now.
The extended gripping width on the right side of the camera gives me a better hold for
steadiness while shooting. I did try the "thumbs-up"
with the hand-grip but, to me, it was a bit of overkill. However, without the hand-grip
it was quite useful. But, the hot shoe mount of the 'thmbs-up" blocks the room
needed to mount a Visoflex ..... and having to remove it to use a flash is just a pain.
Cheapskates like me use self-adhesive dots, bumpers, etc. This one is from Radio Shack. Ugly but very effective, and has been on for several months. Removes with a simple twisting motion. Under $1.00?
The handgrip with bottom plate is obscenely expensive. I'm making my own. That said, I prefer the handgrip and thumbs-up. I have long fiingers, and the thumbie thing helps keep my thumb from hitting the menu button.
First I'm going to try likalar's very cool idea.
Oh, I forgot to mention this concerning the Thumbs-Up scratching the camera.
If you will notice there is a protruding "pad" on the rear of the device just
under the mounting point which protects the camera finish at that point.
Though it protects at that point in use the end of the thumbs-up, at the outward
curve, is where hold force is applied. So, the device "rocks" on the forward pad
and contacts the camera paint at the end were it is used.
Cut a thin piece of the "fuzzy" side of self stick velcro to run from the stock
pad to the beginning of the outward curve.... and this will not only protect the
camera finish, but prevent unnecessary rocking in the camera hot shoe. Cheers.
I have small hands and I find that while having my fingers wrapped around the hand grip, it puts my index finger too far away from the shutter release and makes it awkward to shoot pictures. The Thumbs Up, on the other hand, for me really makes it easier to hold the camera.
I used the same exact 'bumper" as a thumb rest on the back of both of mine used with a grip. Comfortable.
Steve Barnett's "Thumbie" works a treat. Benefits over the 'thumbs up' is no pressure on hot shoe and may be used with flash or aux. finders.
Combined with a StreetShooter, it gives fast access to steady and safe shooting without the 'hand fatigue'.
I was very happy about the MD-grip, which is a nice alternative to the Leica grip. But some time ago I detached it and now I tend to agree that M9 is very handy without any addition.
I don't have any experience with thumbs-up though.
I got my M9 and the Luigi half case with built in grip about at the same time, but had to wait a bit for the steel grey CSEP1. I must say that it was a revelation to pick up the camera and hold it with the thumbs up mounted. I felt that at last the camera was complete!
Regards
Ã…mund
As to those who feel that it puts pressure on the hot-shoe, do you have any empirical reason for saying this or is it just a supposition?
Yes but only with my X1: http://www.l-camera-forum.com/leica-forum/leica-x1-forum/168813-repair-thumbsup-related.html
Anyone's comments in that thread would be appreciated.
I tried both. I currently use a Thumbs Up and find that it helps tremendously with sharpness, especially at slower shutter speeds. The camera feels much more stable and secure with it on. No kidding, it works great. Highly recommend.
The hand grip, although it provided stability, added weight and bulk that to me was undesirable.
If someone says that their thumbs up scratched their camera I simply believe them
that it did. They are speaking of their own experience which may not be the case
for yours. Apples and oranges.
This has nothing to do with the inherent quality of the device or possible stress on the
hot-shoe.
I offered a practical and simple solution for preventing the possibility, too simple
I guess.
Regards
Alex
Basically it is a lever inserted into the hot shoe against which you apply pressure at one end with your thumb. This applies a rotational force attempting to twist the hot shoe off in an anti-clockwise direction. I have no idea if the hotshoe design is such that it will constantly withstand this force.
