How to clean DMR sensor?
fastdap@mac.com
Guest guy_mancuso
if it is grease than use Eclipse and a sensor cleaner swab. If it is just dust blow it off with canned air or a blower brush. easist sensor to clean in all of 35mm.
The DMR is the easiest digital camera to clean from sensor's dust.
Simply open the back and have direct access to the sensor.
I use ArcticButterfly (first model) from Visible Dust and I highly recommend it.
Fast, dry, portable and very effective cleaning tool.
More info on the Arctic Butterfly (newer models) here.
I have just bought and received today the Arctic Butterfly 1.3x Pro Sensor Cleaning Kit:
Digital Camera Sensor Cleaning with VisibleDust Products
It works really well. I needed to swipe my M8 sensor three or four times before I finally got most of the large dust particles off. I took picture with my 35/2 Asph at infinity of a well-lit object (Bisley) at about 20cm at f16 each time, to check the state of the sensor. Now there are just two or three small particles, only just visible at f/16 where I never shoot, but totally invisible anywhere near wide open, where I usually shoot.
I gather that I rather over-bought, since the smaller brush is meant to be used on the "mirror" of the M8 :)
  • 3 years later...
