S120mm review
JMacD
I love the 120
Ed
Lovely rendition.
Unfortunately, for me, the S lenses aren't ready for show time until they all have Central Shutter. It's my understanding that this year will see the first CS lens.
At the rate Leica moves, only God knows how long it will take for them to have a complete line up of CS lenses. But whilst we/I wait for CS lenses at least we can see from the current crop of lenses what the optical quality will be, and it looks lovely.
Regards,
Thank you for the images, Constable.
Do you remember the lens opening for the first two? I take it from the vignetting that the tree in snow image is wide open.
Have you also used an M9 with the APO Telyt? I know the format is worlds apart from the S2, but I was just wondering if you had any comments.
Yes, good question! I'd very much like to know too.
I especially like the first photo, the one with the 'steel carrot' really has beautiful colors.
And the winter landscape, love the atmosphere in this photograph.
Thanks for posting Constable.
I also find that interesting. Looks like added vignette. I think, hope...
Lovely rendition.
Regards,
I'm having my Leica dealer confirm this ... but from what I understand, you can secure the normal FPS lenses and when the CS versions become available, can trade them in for the difference in pricing between the two.
Sounds to good to be true, which is why I'm having it "officially" double checked. However, it could make some sense I suppose, since there are probably more than a few like you that are holding back from buying into the S2 system while waiting for the CS lenses.
-Marc
dear all
Apologies, I hadn't realised the EXIF data wasn't embedded.
ISO 160, 1/60 s, f 4.5
ISO 160, 1/45 s, f 2.8
ISO 160, 1/350 s, f 6.8
All initially taken into LR3, sharpening, colour, saturation etc adjusted in LR3 then opened in CS5 for final working. Fine tuning the sharpening mainly. The vignetting is deliberate and part of the b and w conversion that I did. I rather liked the look. It says nothing about the abilities of the lense!
Thanks or the comments.
I didn't have the M9 with me - sorry
Ed
-Marc
Marc,
The trade-up program from non-CS lenses to CS is still in effect, and is exactly as you describe. Purchase a non-CS now and when CS lenses are released, box up the old lens and pay the difference in price. Pretty straightforward.
David
I wonder how good the HSS works for fill flash in daylight???
If HSS works would the central shutter offer any important advantage if one does not use studio strobes??
Yes.
Speedlights have a flash sync speed of around 1/300 secs at full power, so the closer you can get to this speed before relying on HSS the better.
When using HSS, as you may know, the flash output is reduced in power by a considerable amount. And the faster the shutter speed you use with HSS the more power (light output) you lose.
So it's best to have your camera shutter sync natively as fast as possible so that you can use your flash at full power at much faster shutter speeds.
Thus, having a Leica CS lens with a sync speed of 1/500 is much better than relying on HSS from as slow a shutter speed as 1/160 as you would with the FP lenses(having said that though I do think 1/500 is rather lame when you consier the sync speeds of Phase/Mamiya and Hasselblad gear).
Regards,
I would assume that HSS would work as it does with any HSS flash ... decent for fill at closer distances.
The central shutter would offer up to 1/500th sync speed with full flash ... IF the SF58 recognizes the use of the CS and doesn't employ HSS until you exceed 1/500th.
I'd mostly want CS in a few lenses for use with battery powered strobes while shooting outdoors.
-Marc
BTW, is there an off-camera cord for use with the SF58?
dear all
Ed
Thanks, Ed. I covet a S2 more and more.... Have you used the 180 APO Elmar? I don't know if it is even really available, but my interest is for the 120 and 180 on an SLR to complement my M9.
GP
The 180 is the lense I had most trouble coming to terms with. I thought originally that I had AF issues with it. This is discussed at (great) length elsewhere in the forum. In my case, I am now happy and think that it was a combination of (i) not recognising how narrow the depth of field was when reasonably wide open and (ii) learning the technical details of the AF (and using manual focus for tack sharp images). The last firmware update also made a difference.
The real question, is what the 180 is for. At a 142 mm SLR equivalence it is not really long enough for nature photography. I have been using it for architectural and art work and am exceptionally pleased. But for nature, I reach for the D3x (or increasingly the D7000).
Hope this helps.
Ed
Ed, isnt 180 also a good focal length for head and shoulder portraits and for compressed landscapes...and then maybe for subjects where you want a little more reach?
I am debating myself if I would prefer 120 or 180 (35 and 70 is pretty clear) if I get into the S2 system.
The choice between the 120 or 180 is a tough one and one that I haven't been able to decide. I got to use the 180mm for a week recently in South Florida thanks to David Farkas and it served me very well. I have only briefly used the 120mm, but really liked the closer focusing distance as compared to the 180mm. Both lenses offer exceptional image quality. Its a tough call. I wish I could have both.
Sorry ... I can't resist this one from this morning. i tried using the S2 + 120 as a walk around for half an hour. Not real macro, but getting that way. Hand-held ISO 640, 1/500, f 3.4
Pp in CS5
Ed
Marc, I believe the Leica SF-58 flash will sync at all shutter speeds when mounted on the S2 using normal non-CS lenses. Also, I recall reading somewhere on the forums the Nikon SC-17 or SC-28 off-camera flash cord will work with the S2 and SF-58. Hopefully someone else with first-hand knowledge can verify.
Mark,
You are correct on all counts. Using TTL-HSS the SF58 will sync up to 1/4000th on the S2 with the focal plane shutter (FPS). And, if you use the Nikon cord, high speed sync and TTL are maintained.
David
