Vignetting
Well, the fat Elmar is an 80 years old lens - you can't complain if it shows some vignetting. LR offers a tool to lighten up the edges, if you use it carefully you might achieve some improvement - though on the photo I don't think the vignetting looks bad.
P.S. Are you sure using the right sunshade?
Did you manually code it in the menu before shooting?
Rich
I did; though it is possible that I have the lens in the wrong category. I will check that tomorrow.
The replies have been most helpful. I still have the image on the SD card so tomorrow I will try reloading the image into LR without the 'Develop Settings' and see if that makes any difference.
Certainly with a little fiddling in the develop mode I can remove most of the vignetting. As Steve suggests the picture needs a little darkening at the edges.
I will report back in case anyone is interested.
I thought the "fat" Elmar, which was the first version of the 4/9cm Elmar from the early thirties, had a different optical design than the later "thin" versions. In the Leica pocketbook Puts writes that the optics were not changed and that it had almost no vignetting, which is true when I look at photos taken with the post-war version of the lens on the M9 (same for manual coding as a modern 4/90 Elmar or with lens detection off).
So if Puts is right that the optical design was not changed the vignetting on your photo should not be a "natural" result of the lens. Though if one takes the age of a "fat" Elmar into account, it is well possible that the glass has deteriorated in the zones where you see the vignetting.
OK! I reverted to the original Adobe settings and reimported the photograph:
What a difference! Does anyone set their LR so that it is tuned for the Leica M9? I shall do some more reading around the l-camera-forum to see if I can find any information.
Time now to deal with the dust spots...
Beresford.
