M8.2 Stopped working
andym911
Hi Andy,
Glad it is working again, I have this problem, it happens with either of my batteries just after charging them (one is new and the other about a year old). If they are left for a while or the shutter release is 'fired' a few times the camera comes to life. Personally I think it is the charger, mine is the original 'large' charger that came with the camera.
If you want to live dangerously this evening then charge the new battery and try it again in the camera!
Following your progress with great interest, my camera is still under its 'passport' so if you find the problem I will be onto Leica to sort my camera!
Regards,
David
x
David
was thinking to do exactly that...haven't yet got the balls to do it...the new charger should arrive tomorrow...the small compact one...
....on the other hand maybe a glass of wine and into the charger it goes:eek:
keep you posted
andy
  • 1 month later...
  • 7 months later...
so after getting it sorted last time with a new charger, today same story 9 months later...
dead as a dodo....red light comes on using freshly charged batteries otherwise nothing...a real pain the ass just as I was really getting into the camera again :mad::mad:
Cursing Cursing
Andy
...Don't EVER let the battery drain all the way down. It's certain death, in the near future...
...my battery was completely drained.....charged it up and wanted to continue whooting some stuff this evening....was that a mistake?...
I'm doing the same with third party batteries, failing which they are not recognized by the battery meter of the M8.2, with no harm so far.
It could be a mistake according to Ben's post above (see also Battery University) but full drain is advised by Leica in some circumstances (with new batteries, every 25 cycles and before long storage, see user's manual, page 99 & 155).
For now, i would try removing the battery for 2 or 3 days to drain the internal battery of the camera which should cause a full system reset.
just spoke with CS at Leica and they reccommend the following:
1.Clean both charger and battery contacts with Isopropyl
2.If not successful probably a charger issue and needs to be sent in to CS
3.Leaving the camera w/o battery for a few days to drain will have no effect as the buffer battery would need months to drain completely.
keep you posted
andy
...3.Leaving the camera w/o battery for a few days to drain will have no effect as the buffer battery would need months to drain completely...
Good to know thanks.
If your charger is out of warranty you might wish to try a Delkin or a "Doubice" from a member of this forum.
I have no experience with the latter but the Delkin works fine with genuine and third party M8 batteries.
update......
so cleaned all contacts and after trying 4 batteries and two chargers i managed to find a combination that brought the M8 back to life..:D:D:D:D
one charger and 3 batteries will be sent back to solms to see what the issue is..
happy guy now typing this message
really hope this is the last time i get this
best
andy
