Odd highlighted edges
Bert N
This image was shot with the 50mm f/2.5 and the M8 under bright sunlight. I find the highlighted edges of the leaves very odd, but I'm not sure what causes such artifacts, other than how the camera treats transitions between bright and dark regions.
Apart from the occasional purple edge, I would look to Mother Nature for this. Obviously the edges of the leaves are more translucent than the body, causing them to blow out under the light falling through them. Quite a pleasing effect , though.
Thank you all for your comments. To convince myself that this is not some quirks with the M8's handling of backlit objects, I shot the same subject with another camera, a GH-1 and the results are similar, this was shot later in the day so the sunlight is not as bright as before.
It does appear that the GH-1 jpg handling of backlit edges is a bit cleaner than the M8's - the dark contour at the edges of the bright edges are not present in the GH-1 image but they are evident in the M8 shot. Shooting raw apparently minimizes this (minor) issue.
Not quite. On the M8 shot you have blown out your highlights, on the GH1 the exposure is better and they have been preserved. RAW converters handle highlights differently as well.
