Help! No SD Card detected
adli
I am on a trip to Riga, and my camera suddenly refuses to detect any SD cards. I have tried 3 different cards, all have worked with the camera before. I have tried both to remove the battery and reseting the camera without luck. Does somebody have a clue on how to fix this?
I had the same problem, removed the battery, but didn't reset the camera..
what worked was:::::
I removed and reinstalled the card and everything went back to normal, seems the card wasn't fitting the contacts properly.
Now I am back home and have tried seven different memory cards. The camera still refuses to detect any of them. Tried removing the battery, charing the battery, reseting the camera....
:mad::mad::mad:
Probably the contacts in the slot. I fear a trip to Solms is in order:o The upside is that Leica CS fastracks M9s.
It is on its way, handed it over to the Norwegian importer this morning.
