Shutter Release
chrisduff1
I frequently shoot from a tripod at low shutter speeds. The Leica shutter release cable is able to be attached to the shutter with one rotation of the cable or even less. The result is that it frequently comes off unexpectedly and sometimes requires a fair amount of pressure to release.
The problem seems to be that the casing in which the shutter rests is minimal, giving little surface for the screw mount. Are there any other solutions so that achieve a stronger attachment and can trigger the shutter without impacting the camera? Is there an electronic release available... or an adapter that will provide a stronger attachment?
This has been a frustration of mine for some time, and I'm eager to hear how others have handled this issue.
Chris
Guest mc_k
I've had the Leica release for a couple of years, and not had this problem. You can secure the release with a Twist-tie through the strap lug, and I don't think you'll have this problem again.
I am using a Minox metal mesh covered cable made during the Leica ownership era and it works just fine on M4, M8, M9 and Visoflex. Never come undone with me.
Wilson
