Which flash? A Leica flash?
LDHaber
  • Replies 123
  • Created
  • Last Reply
Even with the flash dialed down, it appears weaker. When I first received the SF58, I took a look at this (partly because the pre-flash of the SF24 bothered me so much), and the SF58 does appear weaker, but more importantly, it appears to occurs closer to the actual flash. My guess, but only a guess, is that the electronics on the SF58 are much faster in concert with the M9, allowing this to occur. The SF24 has a distinct pre -flash, enough to clearly see it with the human eye; whereas, the SF58 you really have to study it to see the separate flash. Almost like my Nikon Speedlights, which are not noticeable.
Maybe someone more technical can address the specifics of the pre-flash between the units.
The pre-flash on the SF58 is hardly noticeable, to the point I don't think about it anymore. Very short, to the point I do not notice it. The electronics of the SF58 is obviously on another level, as is the cost. I found the pre-flash on the SF24 a problem and very noticeable.
Great to know. I may have to consider one of these of I can find at the right price.
Guest mc_k
...Look at the photo of the man jumping over a puddle and don't tell me he wasn't concerned with fractions of a second.
As far as I know no one has actually measured the 24 vs. 58 lag.
I found the M8+SF24 GNC unusable for something like dance, because of the lag.
Apparently the lag may vary with the firmware.
I just got around to rigging the Metz 76 MZ-5 to the M9 and am astounded by the very pleasing results.
I use the Metz's optional bounce diffuser with the secondary direct flash module set to 1/4 power.
The flash gun is a bit large for the M9, but the results are actually well worth it.
  • 6 months later...
Get the Nikon or Nissin system cable. And do read Sean Reid's piece on 'Working With Flash'.
The old man from the Age of Flashpowder
+1
Reid's approach to SF58 on the M8/9 is very ingenious. I use the flash as he suggests off-camera with a Nikon cable.
  • 2 months later...
Are SC 17 and SC 19 the only Nikon cables that allow for full TTL connection with M9 and the SF 24D?
Tks
They should all have the necessary basic functions, but I understand that some of the higher numbered have additional gizmos in the camera connector, like AF focusing light or things like that.
The Nissin cable claims to be universal, i.e. to work with all contact setups, including Canon. I have not tested this (my last Canon was a Canonet 17QL) but it works flawlessly with Leica.
The old man who got his beard singed, occasionally
  • 1 month later...
I've had my SF58 for 2 days and everyone in and around our house is pretty much blind at this point. The dog won't come near me when I'm holding the camera. The Nikon SC 28 cord works perfectly. I don't see myself wandering around with the flash in my left hand and camera in my right very often but it does provide some interesting results and it sure get's you lot's of practice for zone focusing.
I find TTL to be of very limited utility. On my flash there is a definite pre-flash which causes people and pets to blink resulting in closed eyes almost every time. It is somewhat improved with first curtain sync however. Interestingly the preflash and eye blink does not seem to be an issue at all in TTL when the flash is bounced. I have to experiment with this but my recollection is that the pre-flash was very bright so I think it may use the main flash and not the secondary reflector. If that's the case then it makes sense that the pre-flash in bounce doesn't cause the subject to blink. I've got a an-mail into Leica to see whether the noticeable lag between the preflash and main flash is normal or if my flash needs to be calibrated.
The SF 58 is an outstanding bounce flash. I particularly like the results with the secondary reflector set at 1/4 - 1/2 with bounce of the main flash. It's a far better bounce flash than my Canon 580 EX I or II. Results are very consistent and very good.
In A or M mode it's very easy to use. A mode actually seems to better expose for me than TTL. TTL tends to over expose just a bit. Adjustments in M mode are very easy in the menu system but the backlight on the screen should be adjustable. It's too dim.
I generally use flash with the camera in manual mode and it performs very well with standard settings of iso 320 or 640 up to f/8 at 125 which is about as far as I've taken it. ISO 160 actually worked well too.
The size is smaller than the 580 EX II but still large for the camera as others have noted. The size doesn't bother me so much since I really only use flash on special occasions. What bothers me is the diffuculty in setting the speed and reading the f/stops because of it's large foot print. I don't change those much once they're set so it's not a big concern.
I am very pleased with the flash and results so far. 99% of the time it will be bounced and it seems really designed to be used as a bounce flash, at least on the M9. Haven't tried it outdoors but I'm sure when I do I'll be in manual mode. Indoors I had to dial it back quite a bit in manual mode to avoid strong overexposure so it should have enough power for some outside work as a fill flash.
Anyway, just my observations.
  • 6 months later...
Hi all,
I didn't want to open a new thread as I see the topic is the same.
I bought an M8 and wanted to use my SB-900 on it. I hope I won't damage camera nor flash.
As far as I understood I can use the SB-900 but only in manual mode?
How can I trigger the SB-900 when off camera other than a cable?
Which wireless trigger if any would I use?
If I had 2 SB-900s could I use a sb-900 to trigger the other without using any other accessory?
No chance of damage. The camera is rated at 600V trigger voltage. You can use either manual or automatic (if provided) with any non-Leica flash, but for TTL control you need either the SF 24 D or SF 58 D, and some Metz flashed but with limitations.
Hi all,
I think you'll need an adapter to use the SB900 directly on the M9 because the foot of the flash is bigger than the Leica hot shoe.
