Eyelet
x
Are we referring to strap lugs? Or the viewfinder eyepiece? The viewfinder can't easily be scratched by split rings on the strap.
Of course the strap lugs will get scratched by putting on the split rings. They'll even be worn on the inside by the continuous moving of your strap!!!!!
I normally don't criticise those trying to keep their camera in tip top condition, I myself use a half-case and a screen protector. But really, fretting about this is just a little ridiculous. If it really irks you, have them replaced when you get a CLA if they show much wear.
Joking aside, I have wondered about this too. As a wriststrap user I feel both the eyelet and the strap ring are subject to more wear than with shoulder straps, and it is easy to imagine at least the strap ring giving way eventually. Nothing is stopping you from using an all fabric strap though. Might still break, but without the wear on the eyelet :p And then there is Luigi's...
I am not an expert on M6 (and note this is the M9 forum) but a quick search does reveal at least one old thread here about M6 lugs coming loose, and M4 lugs worn down and almost through. That's enough reason at least for me to continue wondering about it.
It is not about me though; the OP didn't state any motivations so why not keep all options open.
The sharp ends of strap split rings can certainly scratch the eyelets which is one reason why I gave up using the wide leather strap, the other being that the length adjustment studs scratch the top cover. If ever there was a Leica product which is not fit for purpose, this is it.
Replacing the eyelets is a major - probably the biggest - job in terms of the level of dismantling required.
The standard strap does not have these problems because only a wire loop passes through the eyelet. If you want to use another strap, look at replacing the split rings with Nikon's triangular equivalent which will not rotate and damage the finish.
Thanks for all your responses. Keep them coming...
Just a thought. Would it be possible to use gaffer tape on the eyelet?
Probably. But why waste the time wen you could be shooting?
I think it is possible to slip some plastic tubing around the metal rings on the strap, possibly just some electrical wire insulation. More luxury version would be silcone or teflon tubing.
Of all the things in the whole world to worry about, this must be on at least page 2.
If you are a collector, the camera should still be in its box and never put anywhere near a strap.
If you are a photographer, you are going to have a completely horrible time with the camera if you worry about the strap lug getting scratched. Give it six months and there is abound to be a scratch in the body somewhere
It's a bit like buying a new car and then worrying about taking it out of the garage because it might get scratched in the car park. That way madness lies...
IMHO, of course.
Yes, the wear on the eyelets is a problem, but not one which keeps me awake at nights.
Take it to an electrician and have him apply some shrink tubes to the rings which go through the eyelets.
Maybe Leica should publish the hardness quotient for the eyelets so that worried persons can find securing rings of a softer material so as to be sacrificial. Just needs watching so that when the ring breaks, the camera doesn't fall to the floor in a nasty fashion.
I've never heard of an eyelet wearing through, has that actually happened? I've always taken care of my gear but it's never occurred to me to worry about minute scratches on a strap lug.
It's a bit like worrying about scuffing the soles of a new pair of shoes!
Could the M9 eyelet be scratched by the strap rings?
Your question seems to have attracted the unwanted attentions of the 'sarcastic brigate', but was a perfectly legitimate one.
Eyelet wear was a problem in older Leica cameras, as the sad state of some screw-era examples shows. Modern cameras have eyelets made of much tougher material, but I can't remember the date these were introduced.
