X1 : Saturation
seemeng
Chaps,
I noticed this with my X1. When I select B&W natural, the saturation menu doesn't work as I can't select it. It only happens in B&W and not under the colour mode.
Is this a firmware quirk or there is a problem with my unit?
Hear soon.
Thanks and cheers.
See Meng
The gray scales are adjusted by brightness, contrast and gamma. "Saturation" means the intensity of the colors. You convert a coloured image to a B/W one by turning the saturation to zero.
Well, it's a bit more complicated than that, but that's the main point.
See, have you messed around with lightroom yet? I would try some DNG files and mess with saturation in LR... then convert it back and forth from color to B&W to see differences. Saturation can affect B&W for sure, but in camera it isn't an option that is associated with B&W.
Thanks Chaps for the feedback.
JS, I haven't manage to download lightroom yet but am planning to get a copy from the local Leica distributor as the bandwidth despite the broadband is killing. Will let you know in due course.
Happy shooting.
Cheers.
Hi, without doing any direct measurements I can't see any difference using your suggestions.
Hmmm... maybe I'm mistaken then... but I could have sworn that it did. I though if you turned the saturation up and then converted it to B&W (by hitting the B&W button in LR), it would look different than if saturation was at 0 and you converted it to B&W (by hitting the B&W button in LR). Even if this did work the way i am describing, it wouldn't be a useful method.
If you change the saturation of a single color you do get an effect. For instance if you change the saturation of yellow, it is like adding a yellow filter on B&W conversion. (or a blue one if you go the other way) To complicate matters, you could also change the brightness of the color, creating a subtly different effect.
