28 mm ?
Annibale G.
Hello,
I was thinking to buy a 28 mm to switch in use with the M 35mm f/2 on my M7.
I was thinking to buy also the R one, cause I have also a R camera model. In that case I will use a 35 and a 28.
I have just some doubt, which is the better among the R model, the M f/2 or the M f/2,8?
Do you think is good to switch in use a 28 mm with the 35?
Thanks
Focal length preferences are so personal, it's hard to say whether you'd get on better with a 28 than your 35, Annibale. I will say that the 35 is such a classic lens, and gathers to itself so well all the powers of the full-frame rangefinder ethos, that I would question a switch unless you have a very clear preference towards the wide end.
I am a bit confused about your references to the R model. An R-model lens is not going to work on your M.
Well... a R lens can be mounted with a ring (22228) that is not difficult (nor costly) to find... and with a 28 2,8 used around 5,6-8 the lack of RF coupling can even be not so significant... if one has a R body, and considering the very low prices of R lenses nowadays, it can be an option...
i know i was making question on M series
OK but you cannot mount a 28mm or a 35mm M lens on a R camera. So if you have a 35mm M lens on your M7 you need a 28mm R lens on your R6. The best 28mm R lenses are the late Elmarit-R 28/2.8 # 11259 & 11333. They are not as good as current M lenses but they are considered among the best 28mm lenses for reflex cameras. I like much the earlier Elmarit-R 28/2.8 # 11204 as well but it vignettes more and corners are softer, at least on my Canon 5D.
oh my god let's put now in a easy question first. It's so difficult talking here :-)
About M system which 28 mm should be better between the f/2,8 and the f/2 ?
Thanks. Annibale
Both are superb lenses. The Elmarit has somewhat higher contrast than the Summicron, and some users do actually prefer the Summicron because of that -- they find the 'drawing' more pleasant. I do find it a lovely lens; I have no experience of the Elmarit. Apart from these niceties, the salient difference is of course one f-stop more speed, and the price. Only you can decide.
The old man from the Age of the 2.8cm Hektor
Guest Bernd Banken
Annibale,
at first you should check wether you are able to see the full brightlines in your Ms rangefinder.
The R makes no problems but the M could be difficult when you are wearing glasses.
I switched from a 35 to a 28 and haven't looked back. The 28/2 is a great lens. So is the cheap CV 28/3.5. Maybe pick one of those up, see if you like the focal length. If you do, then you can think about getting rid of the 35.
Both are superb lenses. The Elmarit has somewhat higher contrast than the Summicron, and some users do actually prefer the Summicron because of that -- they find the 'drawing' more pleasant. I do find it a lovely lens; I have no experience of the Elmarit. Apart from these niceties, the salient difference is of course one f-stop more speed, and the price. Only you can decide...
Yes and the bokeh of the Elmarit asph is slightly harsher than that of the Summicron. Both great lenses anyway. My favourites ever.
