It isn't "my kit" - yet. ;)
It looks exactly like a "real" M2-R,  or an M4 take up system - see pix previously from Samascha and Carbon Dragon (original poster).
Three-pronged "tulip" or "fork" take-up core with a coiled spring inside - not in any way a "spool."  Plastic M4/M6 funnel on the base-plate to hold film on the "tulip" or fork. M4-type loading diagram.
Definitely not the Quick-load spool and guide kit.
It just has an earlier serial number than the M2-R ranges, by 100 thousand or so.
OK - bought the previously-mentioned M2. Here are pictures of:
the top plate and engraving
- and from the bottom, showing the upgraded takeup spool and M4-type diagram
- and the bottom plate.
Questions still are 1) possible upgrade ever offered by Leica? Or is the conversion by a 3rd-party tech? and 2) any particular value over regular M2, since it does not have formal M2-R provenance (not within the usual S/N groups)?
I just noticed another anomaly in this M2 - it has M4 framelines (including for 135mm). Something of a Frankencamera - although I count all the anomalies as upgrades, and the mechnical functioning is A-OK.
Well... it's exactly what was proposed to me, 20 years ago or so, by a then respectable repairer in Milano,  when my M2 , after a fall, was still mechanically good, but with VF blacked out. I already had an M4, and the repairer proposed me to fix the M2 "upgrading" to M4 VF/RF and loading system : I don't know how would had looked the final result because passed by the proposal and kept the M2 unused and damaged (several years after, gave it to Jerzy, who made from it a splendid like new black M2... 😀)
Edited by luigi bertolotti
I'll just assume the same for this camera - an unofficial upgrade with M4 (or even M4-2) parts, by a very competent 3rd-party tech. Nothing to do with the M2-R/KS15 series.
Not a collectible - but perhaps worth a little extra to the right "user," for the added conveniences.
Give it a few years until more obfuscation and rumours kick in,........ but I love it that you got a great camera at your local shop.
  • 2 months later...
Don’t mean to bump an old thread but I want to get some info on my m2. I had never realized that my m2 had a rapid loading system until someone mentioned it to me. I was under the impression that only m3’s had the old style spool. After doing some googling, I’m under the impression that I may have a KS15 4 but hopefully you guys can set me straight. My Leica still has the L wax seal so I’m lead to believe this was factory done in 1960/1961.
  • 1 year later...
I found this at my local camera store, but the plate is missing on the bottom. Can you tell from these pictures if this is a KS 15?  Serial number is 1,162 xxx
Thanks!
5 hours ago, BlackPaint said:
Is this s/n range set in stone? I found another source online that includes it.
Very few facts about s/n of Leica bodies are set in stone 🙂... iirc, even James Lager didn't make a defintive assessment about the s/n of M2s delivered to US Army as KS15  ; also, some other minor details, apart loading system and anti dust felt are somewhere reported.. I do not remember well which they are.... something related to crank lever mechanism.... ?
I believe you are correct.  Unfortunately, this camera has been stripped of everything that would make it a KS 15 model, the quickload plate graphic, the winding lever and ??   ..it does still have a felt strip. I’m at a loss as to whether I should buy it and attempt to restore it.  They’re asking $1000 and I’m afraid it would only be cost effective if it is indeed a KS15.   One thing I can’t tell is the 3 pronged tulip shaped take up spool tip.
