photophile Posted January 25, 2010 Share #1 Posted January 25, 2010 Advertisement (gone after registration) I would like to use a 1959 Yashinon 50 1.8 screw mount , off the Yashica YF Nicca ( M3 copy ) on my M8. What is the best way to adapt the lens..without altering it at all. Milch adapters? All advice welcome. It is a beautiful camera and a lens with marvelous character. Thanks. Coos Link to post Share on other sites More sharing options...
Advertisement Posted January 25, 2010 Posted January 25, 2010 Hi photophile, Take a look here Yashica Nicca Conversion to M8 mount. I'm sure you'll find what you were looking for!
jaapv Posted January 25, 2010 Share #2 Posted January 25, 2010 Afaik I know it is in LTM mount. You could just buy a Cameraquest 50 mm LTM-M adapter. Coding will probably not be needed fo this lens. Link to post Share on other sites More sharing options...
doubice Posted January 25, 2010 Share #3 Posted January 25, 2010 There is no need to permanently altering the lens. All you have to do is to buy an LTM to M mount adapter. Availlable on the Big Auction Site; I would however recommend Cameraquest and their Voigtländer LTM to M Adapter II. You will be able to code that adapter, even though coding is not really necessary unless you wish to see the EXIF data on the M8. Best, Jan Link to post Share on other sites More sharing options...
wizard Posted January 25, 2010 Share #4 Posted January 25, 2010 ...even though coding is not really necessary unless you wish to see the EXIF data on the M8. And I strongly doubt that even if coded the EXIF data will show that it is a Yashinon lens . Andy Link to post Share on other sites More sharing options...
doubice Posted January 25, 2010 Share #5 Posted January 25, 2010 And I strongly doubt that even if coded the EXIF data will show that it is a Yashinon lens . Andy True, all the M8 EXIF will display (with current firmware....) is the focal length. But - this will be the case with all coded lenses, even those produced and coded by Leica. Best, Jan Link to post Share on other sites More sharing options...
photophile Posted January 26, 2010 Author Share #6 Posted January 26, 2010 Thank you all for the excellent information. I will contact cameraquest. Best. Coos Link to post Share on other sites More sharing options...
