Quick Question re Summicron 40/2
piblondin
Hi everyone--
I just picked up a very used copy of this lens for a good price and noticed some eccentricities. I would like to know if any are cause for concern, and if I should look for another copy of this lens.
1) The previous owner had screwed on a filter so tightly that I had trouble getting it off the lens. In doing so, I rotated the aperature ring and the area around the front of the lens that says Leitz Summicron, etc. I was able to rotate the aperture ring back to it's original position.
2) The focus ring is a noticeably more stiff at the close distances, say up to 1m. Then it becomes normal through infinity. It's certainly useable, though.
3) The aperture blades appear o be a little oily, but I'm not sure. How can I tell?
What else should I look for? Thanks!
Second thoughts, eh? :)
If you got the lens head screwed back in properly, as you say, you've got nothing to worry about.
Don't worry about oily diaphragm blades. It shouldn't be that way, but it'll make only a theoretical difference in the image. (Oil in the diaphragm of an SLR lens can hinder its stopping down properly; but on a rangefinder, you're metering at preset aperture.)
Focusing stiff close up? So what? When you want to make it like new, send it in for a clean-and-lubricate. :(
I say, quit worrying and use it. It's a wonderful lens.
And the reason it was available "at a good price" is just that it was going to give you pause later. ;)
So now you've paid your dues. Go shoot! :D
Thanks for the quick reply! It is a beautiful little lens. It makes me happy that I got the Summicron version even though I'd guess the Rokkor is basically the same. :-) It wasn't so much the price that gave me pause, but the issue with removing the filter.
Anyhow, I'll take it out for some shooting tomorrow and then I'm sending my M8 back to NJ for a rangefinder adjustment, which I'm guessing has been the cause of my back focusing woes. Looking forward to getting it back and finally beginning to use this new camera for real!
Actually, though some deny it, the Summicron is better than the Rokkor 40.
That's a case where Minolta used the Leica design but substituted a less expensive glass in one element. That's the story anyway, told me by someone who probably knew.
But--typical reason for Leica's existence--the only time you can see a difference is wide open, so the Rokkor is a thoroughly satisfying lens for anyone. Just not quite as good wide open. ;)
Congratulations. I think you'll be happy with it!
Actually, though some deny it, the Summicron is better than the Rokkor 40...
Did a comparo with the CLE version of the Rokkor some time ago:
http://www.l-camera-forum.com/leica-forum/discus_e/messages/2/117163.html
Hard to tell an obvious difference at infinity at least.
Got focussing problems with the Rokkor on my Epsons though so i don't use the lens any more.
Which framelines does the 40mm summicron bring up on the M8 and how are you dealing with the inaccuracies?
It brings up the 50mm framelines. Once I get my camera fixed, I will shoot more with the lens and decide if I'm going to keep it. If I do, I'll probably file it to bring up the 35mm framelines, which I find to be fairly accurate at most distances.
...the 35mm framelines, which I find to be fairly accurate at most distances.
Depends on the camera i guess. Beware that the M8.2's RF is set to be accurate at 2 meters contrary to other bodies. So don't file your flange before you make sure it works fine if you use a M8.2. Just my 2 cents advice.
