135 2.8 w/goggles focus issue
stonearabiapix
Hello all, and happy holiday's
Does anyone have any experience with using the (135 Elmarit 2.8 w/goggles), lens on an M8? I am having an issue with severe back-focus when using this lens. I focus on my subject and the lens will be sharp 6-8 inches beyond. at infinity its hard to say where the focus went! Anyone with any experience with the same?
Any ideas? any way to fix?
any help would be appreciated.
Tim
Me too had the same issue... even if don't care too much of, having a Tele Elmar 135 which works perfectly... the Tele Elmarit 2,8 has a RF cam-adjusting screw which is rather easy to operate and this is surely a way to tune the focus... I did and verified that with much patience and attention one can probably adjust focusing by himself... in the forum I saw perfect focused shots made with it, even if I prefer the TE f4.
mine had also had a focusing problem when i bought it. i sent it to will van manen in the netherlands for adjustment and milling the slots for 6-bit coding. it worked perfectly after that = nice lens on the m8.
good luck
rick
Good to hear I'm not alone, and others have found solutions. I've also heard that I might be able to "shim" the lens, buy taking the lens head off and adding shims to the rear of the lens barrel. Anybody do this?
You need a collimator to do this - plus a selection of shims.
I did a very similar work on an old Summicron 90 screw mount, indeed in a very rough way : attached two thin SCOTCH stripes onto the cam surface, refiling with a razor blade... it worked no bad (but, to be clear, is a lens I keep as a collectible, not for using... was just a try of supersimplified do-it-yourself adjustement... :p)
