Battery Usage at below -10'C
Guest BigSplash
Guest BigSplash
I am planning to go skiing and want to take my M8 with me. ...and in future a M9.
In years gone by it was the norm to have the Leica M4 for example winterised (oil removed) and on my Beaulieu Movie camera I used to use a battery pounch that I kept in my ski jacket pocket (to keep it warm) and the gave power via a cable to the camera.
Question: Does anyone have experience using a M8 or M9 at very low temperature...minus 30'C to minus 10'C. I shall have two batteries fully loaded each day.
Yes I have.It is quite possible to use the camera in the cold, but do keep it under your coat as much as possible, and do keep the spare batteries warm in your pocket. The main enemy is internal condensation - watch out for that - it can kill cameras.
Guest BigSplash
How do you avoid the condensation......I guess if the camera has been in the cold all day (snow conditions) and then you wander into a warm hotel room that is likely to be ideal to get condensation.....do you suggest keeping the camera minus batteries but with lenses in the car boot during the night, and allow the camera & lenses to gradually (ie very slowly) reach normal temperatures on the journey back home?
No- just put it in a closed plastic bag outside, when it is cold, take it inside and let it warm up inside the bag. You can take it out when temperatures have more or less equalized. DON'T LEAVE IT IN! In the car boot is not a good idea. If the temperature comes to the dew point there you will have created the circumstances that promote condensation.
it 's bound to be better than my first digital Leica, the Fuji built Digilux Zoom in 1999. It used 2 AA NiMH batteries and in cold weather below 0º, you could get about 2 shots. Eventually I found that non-rechargeable Lithium AA's was the answer.
Wilson
I can't vouch for minus 30'C, but I have been out today and the wind chill got it down to minus 8'C. Starting with a fully charged aftermarket battery I got 200 uncompressed .dng files with no review but some chimping, before it stopped working.
Steve
Guest BigSplash
Jaapv ....After hearing about five Eurostar trains stuck in the euro tunnel it seems that condensation is an issue. Those trains apparently went from extreme cold to humid warmth in the tunnel and seemingly suffered acute condensation as a result. I guess a digital camera and its lenses as you point out would behave in much the same way if you go from cold to the damp hot of a ski hotel.....so thanks for the advice.
I am reading here that batteries, especially if a spare is kept in a warm pocket are less likely to be an issue.
Thanks to all of you for the feedback.
