M8 viewfinder
jamalsan
Hello everyone,
My father had a M3 leica coming with various lenses, including the Hektor 135mn, which I inherited. I understand that the M8 doesn't have any frames for 135mn lenses and I was wondering if an external eyepiece showing 135mn frames were available for the M8. I read here and there posts about 1.4 magnifiers, but, correct me if I'm wrong, they only magnify the view, they don't add 135mn frames, right ? So they help focusing but not framing. I set the hektor on my M8 and I didn't find focusing difficult. On the other hand, my pictures are of course out of frame, in spite of all my efforts...
Also, I found a Leica SHOOC:
LInk to eBay removed by moderator
unfortunatly, I have no idea how to use it...It seems it goes on the flash shoe. Is it useful with a M8 ?
Thank you for helping me.
x
Hello everyone,
You will need a 180mm viewfinder for 24x36 (35 mm) format.
This page may help you.
Epson R-D1: Accessory finders
I'm back to you. I've decided on buying an external viewfinder for my 135mm Hektor. But lately, I've been browsing the web in search for information about long focal lenses and I've come across articles about the Visoflex III and the M8.
I think that with a Visoflex, my framing issue would be sorted out, though carrying the device would turn out to be a heavy experience. What do you think ? I've checked ebay about Visoflex III and those I could find are mint and their prices most reasonable.
There is one being sold in the Buy & Sell page of the Forum in the Lenses section.
By the way, when I use my 135 on the M8 I keep im mind the that the frame is someway between the patch and the 90mm framelines, half way more or less. Pushing the lens release button and turning the lens leftward a bit it brings up the 90 framelines.
Let me say... Visoflex is NOT the solution for using 135 on M8: Viso is a very interesting device, and oldtime Leicaphiles (like me) have used it for years and years, but it is a rather complex device to use, and not so often usable without tripod: its right field of use is for macro photo (also with its very fine bellows) or for long teles (280-400-560) with which tripod can be acceptable; 135 is a straight lens to be used in normal situations, and the best thing to do is, as Enrico and Nicole said, to use rangefinder patch and 90 mm frame as references: 135 stands indeed between the two.
Allright. I might invest in a Visoflex III someday, but I now know that I'll have to find another reason for it than using a 135mm ! I've created a gallery and posted some pictures taken with my M8 and the Hektor. Check them out when you have a chance : Flickr: jamalbee's Photostream
Comments are welcome. They were taken without the external view finder that I have just ordered and without the "Pushing the lens release button and turning the lens leftward a bit to bring up the 90 framelines" technique.
  • 1 month later...
Hello !
Me again. Thank you epand 56. I have posted new pix taken with the Hektor. I'm satisfied with the results, but I find the colours not to be vivid enough. Is it because of the lens or the M8 white balance settings ? I'll try some other settings to sort it out.
I would like to talk about another 135 mm lens. The Elmar 1:4/135 (the serial number of the one I found on the evil bay is 1768557). According to the visoflex III instructions, the lens unit fits the "oubio" part to be mounted on a visoflex III. A friend of mine lent me an oubio and I must say the elmar lens unit doesn't fit it.
Have I missed something ? Do I need an adapter to screw the Elmar on the...adapter ?
Please see the enclosed pictures. My finger is pointing at the threaded part of the lens unit which cannot be screwed.
The OUBIO - or No. 16466 - does not fit an 135mm-Elmar. It is made for the 4/200 Telyt or longer lenses.
For the lens-head of the 135mm Elmar you can adapt the 16471 to fit on the mount 16464 for the Visoflex to use the lens for close distances. You find a chart for adapting lenses on the Viso here in german and in some other languages if you look some postings further on in the thread:
http://www.l-camera-forum.com/leica-forum/leica-collectors-historica/109262-anyone-got-copy-visoflex-adapters-chart.html#post1153818.
To come back to the original question about a separate viewfinder for 135mm lenses on the M8: There has been the TEWE-Viewfinder from the 50s which had a frame for 180mm, which is the cropped focal length of 135mm on the M8. Though I don't think it is really useful. Much easier to "guess" the right frames between those for 90mm and the rangefinder patch in the center.
P.S.: Most famous picture of the TEWE on a Leica is this one:
http://www.l-camera-forum.com/leica-forum/leica-sammler-historica/42415-viooh-vs-tewe-zoom-sucher.html#post459310
Indeed the shot is impressive !
I have found an external viewfinder for the Hektor, but as you said and just as it's been mentioned by others, I'm just bringing up the 90mm frames and shoot. It is the easiest method, by far.
Thank you for the precisions about the oublio.
Yet, in my Visoflex instruction leaflet, it is stated that the OUBLIO ring (or 16 466) is to be used with lenses from 125 to 400mm. The french leica aficionados site summilux also describes the OUBLIO as an adapter ring for the Elmar f:4/135 mm, among other lenses (in short focusing mount only, Leica - Dictionnaire , in French). This is what puzzles me. My leaflet also mention a filter turret 14 116 between the OUBLIO and the lens. I haven't got the slightest clue about what is a filter turret. Can it be that, according to the Elmar production year, the OUBLIO may be or maynot be used ?
A 135 lens head will fit onto the Visoflex using the Universalschnecke 16464 or the bellows. In both cases it will focus to infinity. The filterturret is one of those weird and wonderful - and rare and expensive contraptions Leica used to make.
To UliWer :
hahaha, I guess this is a Freudian slip ! I know deep inside myself I should forget (oublier) the OUBIO...
No, no! It was good to remind us about the good old OUBIO.
The OUBIO has a M-mount bajonett on one side and a 39mm-screw-mount on the other. So I tried if a 4/135mm Elmar with screw mount would allow you to take photos with the OUBIO on the Visoflex. The result was this:
Distance sensor to objekt about 57cm; the ratio is approximately 2:1; the depth of focus in which you can achieve a sharp picture is very shallow, though I think you cannot deny that it is sharp. If you find the short focussing mount for a screw-mount 135mm you should be able to use the lense together with the OUBIO in a broader field.
And you can add the ring 14020 between the OUBIO and the lens:
Though with a bellows you can achieve those results easier and much more precise.
