A strange item
seen on a Leica IIIa 211xxx, what can be this strange item on the winding knob ?
x
Very strange, obviously some home made device. It would appear to stop the winder knob from being used but also means that the rewind lever cant sit in its proper position. I would suggest that its a device to make multiple exposures, i.e. hold the film in place, disengage the gears and cock the shutter with shutter dial?
I can't see any other reason to 'lock' the winder, although from experience on my lllf if the rewind lever isn't fully in it's home position the shutter malfunctions - it trips but doesn't always open.
Very strange, obviously some home made device. It would appear to stop the winder knob from being used but also means that the rewind lever cant sit in its proper position. I would suggest that its a device to make multiple exposures, i.e. hold the film in place, disengage the gears and cock the shutter with shutter dial?....
Ugh... can one act like this ? Anyway, your explanation has a sense; btw I notice that the "accessory" required, apparently, to make a small hole (threaded ?) into othe top plate... not a fine operation to do...
I don't see anything threaded into the top plate?
If it was a rapid winder it almost certainly wouldn't work because the rewind lever can't sit in its proper position.
Curious...........
I meant this...looks that sort of ratchet is kept firm with a sort of "pin" someway fixed onto the plate... but who knows...
Luigi, that is a 'stop' for the rewind lever (present on my lllf's) although I'm not sure if all the earlier cameras had it.
The device has been made to lock onto the pin for some reason and I can only think that it is to prevent the film being wound on. It definately looks like a crude home made thing!
Gosh... too much time I do not handle my LTMs.... :o
And indeed they have the pin... :o
My IIIg (879xxx) does not have it.:confused:
On reflection I think that this is indeed a double-exposure device. With the A-R lever in the midway position shown the shutter is uncoupled from the film advance mechanism but the shutter release works normally. In this state you can cock the shutter by turning the speed dial and thus make multiple exposures.
The device on top of the wind knob (a) locks the film transport to avoid accidental movement and (B) marks the position required for the A-R lever. In addition I'll wager that it's spring-loaded so you can pull it up to disengage the locking tag from the pin and then advance the film ready for another batch of multiple exposures.
  • 2 months later...
Seeking for an another item in the James Lager book Vol III Leica Accessories p51, I found this one :
the Rapido that matches verywell with the one that we discussed about and in fact even if the original picts are no so good we can see that something was engraved on the top.
(study and study again !)
That's the fellow! Curious device, sounds dangerous - risk of chopping off a finger on some cheese-cutter type wire!
I wonder how much faster it was in practice? I can wind my lllf pretty quickly by holding the knob and turning the camera, but I'm not usually in that much of a hurry!
