Showing results for tags 'slide film'.
I am successfully developing at home C-41 color negative (and XP2 B&W) and E-6 based slide films using the Arista development packs. After I started recently working with the E-6 process, a few differences compared to C-41 became obvious to me regarding the recommended steps in the development procedures: 1. E-6 requires washing with water between first developer and color developer, and then afterwards before adding Blix. C-41 has no water wash in between developer and Blix addition - why? Would it be better to add a washing step in the C-41 process similar to the E-6 process to avoid contamination of Blix and stop the developer? Or is there a reason that this shouldn't be done? 2. E-6 has no final stabilizer wash as it is done in the C-41 process. I understood from earlier discussions in this forum that the stabilizer acts to preserve the color negative - any specific reason why this is not needed with slide film? 3. Is there a difference in oxidation stability of the developer used in C-41 and the two developers used in E-6? Are both color developers in C-41 and E-6 the same?
