Showing results for tags 'sf 40'.
Found 1 result
  1. I have a problem to get the SF 40 flash working on the CL camera. All the settings are as per the manual and the flash setting is on TTL but the flash icon on the display is crossed out meaning the flash will not fire although the camera flash setting is on. I have tried it on manual and auto but it still does not work. The flash tests good when I press the test fire, I have also changed the batteries but have had no success. I was hoping to get information from someone who may have experienced the same problem as I have.
