Showing results for tags 'leica md'.
I am thinking of buying a Leica Q3 even though I have the Leica M (MD) - which I am very happy with. But Q3 that's a COMPLETELY different camera. But Q3 has AF, Video and 28 too about 75(90) mm. This is the area I use the most on my M.(24mm-50mm) I don't want to go the SL route now but have the Canon RF because of the long telephoto lenses for bird photography AND amazingly fast AF. But I'm a little afraid that the Q3 will replace my M and it will collect dust. But Q3 + an M with 50mm Is there anyone thinking of doing the same or has done the same with the Q2 ?? (I am definitely not going to sell my M equipment)
Hello, Since sime days, i this idea, of getting an Leica M again. I've used one in the past, but switched to the Sl system instead. Since i currently able to afford an M10, used or new, i looked ar older Models. The M9 and M8 came to my mind at first, but then i got another idea: there are leicas, like the m1 or M-Da. You can get them for like under 600$. What if you took an Digital Camera disasamble it and put it into an M-Da? Has anyone else had this idea, or even tried it? If yes, which camera did you use? Im Still debating on the fact that it kinda would mean to "disleica" an camera, but since its an M-Da? Thank you for your answers
