Showing results for tags 'hdmi monitor'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 2 results
  1. Maybe someone who knows more than me can help... or even someone working with an SL and e.g. an Atomos. Leica's list of video resolutions adds information over what's possible on SD or on HDMI... But I'm confused about what the Mbps information means... shouldn't these over HDMI be dictated by the recorder and video codec being used? For example: Leica states the SL2-S can only do Long-GOP 150 Mbps when using UHD and 24fps (while C4K 24fps strangely uses All-I 400 Mbps). That definitely is the internal .mp4, but is that also applicable to HDMI recording? I hope that doesn't mean the SL2-S can only push 150 Mbps through the HDMI when choosing UHD 24fps? (ProRes422 HQ has target data rate of 707 Mbps in UHD 24...) I mean it should be possible theoretically, because the SL2-S can do C4K 24fps ProRes Raw recording over HDMI after all... The SL2-S can do 150 Mbps in UHD 24fps, 400 Mbps in C4K 24fps. The SL3 can do 400 Mbps in UHD 24fps and 600 Mbps in C4K 24fps. That is interesting... nice one SL3, but over HDMI they all should be equal... right? Is it a raw stream over HDMI that then will be recorded as 707 Mbps ProRes422 HQ? To make matters worse, some of the information is split between SD and HDMI in the list of the SL3. (Have mercy on me I never had an SL but consider the SL2-S now) My head spins 😂 I hope someone has the answers! THANKS!
  2. I’m using an Atomos Ninja V 5” monitor driven by the SL2’s HDMI port. It displays the viewfinder image just fine, but none of the AF tracking and exposure data shown in the viewfinder. This gives me a very viewable display at low camera angles - the eyepiece no longer gets in the way, and I can actually see what I’m shooting. ** Is anyone else using an external monitor, and how do I get the AF tracking point and exposure info I see in the viewfinder to appear in the external monitor? Right now all I get is the viewfinder image. I have to place the AF tracking point in the middle of the viewfinder and put the subject there when I’m using the external monitor without knowing if I’m AF tracking or not. Thanks..
