Showing results for tags 'firmware sl'.
Found 4 results
  1. Hi This evening I updated the firmware for my SL2 to 5.1. Unfortunately, as soon as I did this the camera displayed the following message: 'Lens firmware not supported. Please update firmware.' I have downloaded the latest lens software SL Lens 09, but when I go into Camera Information the Lens Firmware option is greyed out. I'm really at a loss regarding what to do next. My lens is a native Leica SL 35mm F2 Apo. I have tried removing this and reattaching but nothing seems to work. Many thanks
  2. ProRes LT 4:2:2: 10 bit to internal SD For SL2-S (and SL-2): And if bitrate too high for saving 4K on V90/high speed card, then at lower resolutions, please
  3. Hello Leica friends, I wanted to bring to your attentions some issues I’m having with the Leica SL2.. I have bought this camera mainly for Video shooting as I use M10P and M6 for photos. I loved using my M lenses on the SL system and when the SL2 was finally announced I thought it was time to get one. I tested every shooting mode and I have to say that the camera has received some big improvements compared to the previous 601. The Ibis is very accurate and in HLG mode the dinamic range is quite impressive. Didn’t like the LLog though, very noisy and difficult to handle. And the internal 4K 60fps is just useless for aliasing and moire (you must use an external recorder if you want to get a decent file, when the Panasonic S1H is very clean in the same mode). I also use for my work Alexa Mini LF and smaller bodies such as the Z-Cam F6, this last camera has a nice M mount with positive lock which enables me to use all my Leica M lenses. So why I got a SL2? The main reason is to be able to carry it everywhere, in a small backpack with a couple of lenses, other than on set for work. Now, the files produced by this camera should be H265(?).. but the files won’t play in my machines. The finder doesn’t show any preview, QuickTime doesn’t read them. VLC plays only the first 3 frames (18cores IMac Pro).. imagine you shoot 300 clips and you need to conform them every time to Prores in order to just see what you have shot. I remember I bought my SL2 in Shanghai the day it came out and after 2 days shooting around I just switched to my small Zcam as I had to open at every import FCPX or Premiere and create a project just to watch my daily footage and after delete it. So my question: having a playable file out of camera (internal recording) is Asking too much? Another big limitation is the focus magnifier that doesn’t work while recording. With an Atomos Ninja V the resolution helps but as I said.. why I can’t enjoy this camera as it is? I’ve also got multiples hot pixels, partially removed by the internal NR.. but still present. Last, a few times I’ve used an L mount lens... the camera can’t handle video recording for more than 10 min with a fully charged battery. I won’t give up with this camera as I strongly believe a new firmware will fix these problems. what do you guys think?
  4. Hi, as you have probably read the "title" you might already have an idea what my Problem is, but im going to give you a bit of background story. I hope its goint to make it more understandable. So i got my leica SL 1-2 Years ago. Since then i have updated the Firmware some times, since the 3.4 Update, i didn't do any updates. So a few days ago, i updated it, and lets just say, it wasn't the smartest decision. It locked the MC-21 out (which previously worked), and also some other lenses, i borrowed from a friend also didn't work. So now, is there any way i can like downgrade it? I tried "updating" to an older version but i just got an error. Please, if someone knows a solution to the problem, i would be very glad to hear it THANKS in advance!!
