Showing results for tags 'd-lux7'.
I bought a pristine D-Lux 7 a couple of months ago from an (apparently) well respected dealer. Camera seems super, and I am really happy with the results so far. However I was giving it a clean and noticed that part of the "O" and a complete "F" have disappeared from the word "OFF" at the on/off switch..... photo attached. I don't for one minute think a company like Leica would produce a camera where the text wears off so quickly? The seller sent me lots of close-ups before I bought, and the full word "Off" is clearly there. I've taken maybe around 1000 shots only, but won't have switched it on/off anything like that many times, I'm sure. Everything else seems fine (except for a missing "Wi-Fi" section in the menu but Fotos works OK so assume that's me not reading the manual well enough yet.) Has anyone else had experience of this..... or have I bought a copy/fake??? I can't believe it's a copy because it works so well.... but equally I can't believe the text has rubbed off so quickly either! Any suggestions or ideas would be welcome. I posted same on DP Review forum too.... any insights from anywhere would be great! Thanks.
Will the Leica the CF 22 flash work with the D-Lux 7? The CF 22 instructions state: "All flash operating modes are also available when the Leica CF 22 is used with the Leica D-Lux 4." Several weeks ago I sent my question to Leica New Jersey technical support, but haven't received a response. I haven't put the CF 22 on my D-Lux 7, not wanting to break the camera in case the flash and camera are incompatible.
Hello, on the D-lux7 I presume the quoted 24mm angle of view at the wide setting is for the 3:2 ratio. So what would the horizontal equivalent angle of view be at the 16:9 ratio? Would it be something like a FF 20mm lens? I know that the diagonal angle of view is constant at all ratios, but the horizontal angle of view will be different for different ratios. I would be grateful if someone could give me an answer. Thanks in advance!
Hi, I have both a Leica Q and a D-Lux 7 and I use Lightroom to edit my pics. I have quite a bit of purchased presets as well. With the Q, no issue at all. With the D-Lux, even though my picture are taken in colour and imported in RAW format, some of the presets think the picture is black and white and show me options only in B&W. I have to manually go to the Colour option and click on it to see what the reworked photo looks in colour. Anyone with the same issue ? Thanks.
I have a new D-Lux 7. If hold it and give it a gentle shake (no strap, no lens cover... just the camera) there is a slight rattling noise coming from the the lens. If I hold the lens and shake the camera, the rattle is still there. If I put the lens cover on, the rattle still exists. Is this normal? Does anyone else have this? Robert
