Showing results for tags 'copy stand'.
Found 1 result
  1. Is it possible to couple an iPhone to the SL2 so that it can be easily used to view from the front of a vertical copy setup with the camera facing down (e.g an enlarger or Bencher type arrangement). I want to be able to copy slides, 35mm/6x6 negatives and prints. If this can be done are there special cables or connectors that are best to use?
Γ—
Γ—
