Showing results for tags 'cable release'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 2 results
  1. I lost my cable release which I had used on my M10 since I got the body about two years ago. So I bought a new one (A Leica one) in the Leica Store in Mayfair, London. It worked for the first day, then stopped working. It's odd because you wouldn't think anything could go wrong with something so mechanical and simple. But it has. When I press the shutter release at the end of the cable, the prong at the other end does not stick out (the action what would normally trigger the shutter). I can't see anywhere to screw it tighter etc. All idea welcome as I can't easily get back to the store to return it.
  2. I am using an S1R as my backup to my SL2. I cannot get the official sl2 cable release therefore my question is : can I use the cable release from my S1R which has a thinner body with the SL2 with a simple adapter as they both have the same number of contacts. Using the phone app is not the right solution for me because of the small time delay trying to shoot at moving birds in a nest.
