Showing results for tags 'SF-40'.
I am trying to get my head around flash on the Leica Q, I own the SF-40. It's a good match for the Q no doubt about it and pretty straight forward, but I came across some issues. Setup: on-camera flash SF-40 for fill, Aperture priority mode, Auto ISO disabled for flash photography, Aperture usually between f1.7 and f2.8 1. On the Q there is regular flash mode and long exposure mode (I am ignoring the Auto-Flash Option). The latter does not fire at faster speeds than 1/60th. Normal mode on the other hand won't let me go slower than 1/60th. I find this a little cumbersome, it would be good to have the flash fire from 1/2000th up to lets say 1 sec without changing the mode, is there a way to achieve this? 2. Is 1/2000th (still very nice to have compared to other cameras) the Qs max shutter speed that the SF-40 can sync with? HSS, which the SF-40 is capable of, usually goes higher. 3. The TTL flash compensation dial seems to override the Q settings, but it only allows -2/+2 max compensation. Any way to get the -3/+3 the Q has to offer? 4. The SF-40s zoom is set automatically when mounted on the Q. I can't change it manually. It clearly doesn't fully cover the 28mm frame though. I can get around this by using the plastic cap and/or wide angle diffusion screen but still... 5. What are the off-camera options? I think with a Nikon TTL-cable 1/2000th of a second and TTL should work? All in all I am looking for an easy and predictable workflow for direct fill flash or indoor bounce with this setup, that works in most shooting scenarios. Thank you very much.
Which one is better? 1, can SF58 mount directly on M240 hotshoe slot without adapter? 2, The compare functions of SF58 and SF40 TTL, AUTO, HSS and etc. ( in direct mount). Which better? Thanks very much. Need make a decision soon.
