DXO Review
vintola
  • Replies 71
  • Created
  • Last Reply
"DISCLAIMER: This dxomark review evaluates only the selected camera’s RAW sensor performance metrics (i.e., Color Depth, Dynamic Range, and Low-Light ISO), and should not be construed as a review of the camera’s overall performance....."
Other than that - confirms the M9 CCD is still noisy (we didn't know that already?) and that there is some noise reduction applied even to RAW images at ISO 320 and above (which Sean Reid reported 6 months ago).
An interesting comparison - Nikon D3X and the M9, using the detailed charts for 18% SNR, Color sensitivity, tonal range and so on. Except for DR, the charts more or less overlap exactly. Same with the Sony A900/850 and Canon 1Ds (the only comparable cameras in pixel count and full-frame).
Nikon D700 beats them all on noise - which is why I'd like to see an M9H with 12 Mpixels on full-frame.
Kind of makes me wonder if sensor performance as measured in this way is really representative of the image quality that you see when compared to some of the higher ranking cameras. For instance the illustrious D3 with all its advantages, majestic as it otherwise is, I ditched in favour of the M8 IQ and that was over a year ago. The M9 is only better.
It is still an interesting read though. I would still like to know how good all the currently available image processors really are at getting all the measured details out of the RAW file that comes out of the camera, not to mention onto a print. I.e. does any application currently do the "optimal RAW conversion" (quoting the Q&A) ?
If DxO had a chart for "image quality to camera size ratio", the M9 would rank very highly, if not at the top, thanks to its small size. I do wish the M9 delivered numbers like the D3X, but on the positive side, it is in very good company with the 5D, which is a great performer.
That would be the 5D...NOT the 5DII
yes, unfortunately. the M9 has great IQ to camera weight ratio but sensor tech of at least 4 years ago. worse with the S2 though, the M9 is at least a lovely camera, albeit with sensor shortcomings.
p
Of course it is a very specialized CCD sensor with micro lenses. And have you ever compared the size and weight of a Canon 35 1.4 to the Leica?
Story here is if you want/need a Canon, get a Canon. If you want/need a Leica, get a Leica. Nobody's forcing anybody to buy/use something they shouldn't. End of story.
A comparison of the DxO charts for the Leica M9 and M8 and the Canon EOS 5D and 5D Mark II shows that these four cameras perform similary with regard to noise (as seen in the SNR graph). But for some reason there is a huge difference with regard to dynamic range: again, the M8 and the two EOS models perform similarly, but with the M9 the dynamic range drops mach faster – almost exactly by one EV for each doubling of the ISO setting. A linear drop is typical for larger ISO settings, but only with the M9 (not with the M8!) is it linear from ISO 160 onwards. At least according to these measurements.
Has anybody around been able to match these results with what we see in our images?
Photographic "quality" is very subjective. How often do you try to shoot exactly the same image under tight control with two different camera systems? Even then, you might need a scene or subject that can exploit the differences between the two cameras. And shooting the images is simply the first step. Carefully adjusting the raw file is often crucial to getting the most out of any image.
Yes. It occurs that I know a few things about DxO, having been shortly a beta-tester for them a few years ago. And they used my M9 for their report.
For instance, a friend of mine is currently testing plenty of Leica lenses (more than 80 so far) using DxO tools and the results matches what I see in the pictures.
So far, so good.
But when I read their DxOMark figures, I'm always surprised and I do not understand how they translate on real images.
I have a lot of excellent "real images" that I've taken in jpeg using a tiny p&s camera. As long as the camera is used within its limitations, it works great for me. (And I adjust the jpeg images in post.)
The point is that if one is not capable of getting good pictures with an M9 or any DSLR, then one should pack it in and find another hobby/profession. But there also was a reason why I dragged around a view camera for more than 30 years.
I am not technically savy, but what I love about the IQ of the M9 more than anything is the quality of the colors it produces relative to other high end caremas I have used. I find that they are more natural and very difficult to match in pp from raw files of other cameras. Does the DXO info capture this aspect of the IQ in any way? I am not particularly concerned with noise/iso results, but dynamic range is a big deal and I can't say i'm paricularly impressed with the dr of this camera.
Wow Charles, a bit defensive here. First, I would never trade my Leica for a Canon- actually I own a Canon 5DII (and both Canon and Leica 1.4 primes 24-35 and 50mm's), but I still prefer the M9 and these tests wont change that. It still doesnt mean we cant read the test and discuss them here. The story has not ended, if you dont want to hear it then go read another thread.
