M (240) Electronic malfunction?
Delnevo
Trying to use my M (240) on Christmas day, the LED did not come on. I changed the battery and memory card even though I knew these were both good. When the main switch was turned to 'S' and the shutter depressed slightly, I obtained a 'flashing' "Sd" or "5d" (I assume it was most likely 'Sd'). I tried other good quality and fast SD cards. There is no Live View, and nothing on the Monitor. The camera is effectively dead. If I fully press the shutter it sounds as though a picture has been taken, but the SD card is empty. I also tried using the EVF but there was no LED 'on' light, view in the EVF or anything other than a black EVF view.
Any thoughts, ideas, or similar experiences?
I would suspect that the contacts for the SD card don't work as they ought to. In the best case, there might be some dust or dirt in the card slot. In the worst case, the contacts are defective and need to be replaced.
That's a disappointment, for sure.
Ict and Pop, thank you both. The view monitor is completely black with and without an SD card. There is no LED light. Looking through the view finder I can the (white) frame lines, and also the flashing 'Sd' and the bottom, so it's not a complete power failure. Very frustrating.
Ict and Pop: Based on what you have said about possible 'contact' issues, I removed the battery and SD card and used my blower - just incase there was any dust etc. I replaced the SD card and battery, and the camera immediately came to life :). So it looks as though I may have had some dust or something either within the battery or SD holding places. This is great (many thanks for the idea), but leaves me uncertain whether i should have it serviced (bought new in June 2014), or just put this down to an unfortunate experience/piece of bad luck?
Phillip: Good thoughts. I will give the shop and also Leica a call after the holidays to see what they say. For the moment all seems well, but it has 'challenged' my confidence a little, and I missed wonderful photo opportunities yesterday. Thank you and others again for the very helpful feedback. It is very much appreciated. Best wishes for the new year.
Delnovo
Let's just hope it was dirty battery or other contact area. In case it was the battery compartment which may have had some lint or something left in there from a battery change, I have a suggestion.
Do not just put a bare battery in your pockets as they can pick up lint from clothing. I now use Thnk Tank battery holders for organizational needs plus a way to make sure the battery contacts not not pick up anything foreign to camera operation and stay clean.
You should be fine now that it is back operating as normal.
Wrong tree. It was the SD card slot, not the battery slot, it seems.
I never said the problem was the battery slot. What I said was "You'd think for almost $200 they could provide the M240 battery with an end cap to cover the contacts like the M8/M9/MM/ME batteries have". A statement I stand by.
Just some other loose fodder to drop and lose.
