Elmar 3,5/50mm 1948 modified ?
telewatt
I found in a Lens part list (1952) two different Elmars listed.......:confused:
You can see the different Numbers of the parts, lenses and drawing (the drawings are missing...:( ) (from Lens No. 650 701 was the new one)
All the other lenses (Hektor, Summar, Summitar, Xenon, Summarit, Summarex Hektor) are listed only one time....
[ATTACH]241159[/ATTACH]
[ATTACH]241160[/ATTACH]
[ATTACH]241161[/ATTACH]
regards,
Jan
Interesting manual; but I think is not strange that there are different parts for Elmar 5... it is reported (Lager) that the lens underwent modifications in the years after WWII (and, notice, the code of the lens assemblies IS different, whilst some other codes are the same)... I do not remember exactly (no docs here) but the optical modification seems to me coincident with the black scale to red scale switch... which can explain other different codes in the above pages
The other lenses had modifications too, but only the Elmar has two sides here, so it should be a important change for technical work and for the lens too, but you can't find it in the literature like Lager......they all talking on "red scale" change 1952....:rolleyes:
it does not make a sense for me doing two pages with a turning point No. if it is not a bigger change.....:confused:
the problem is the drawings are not in!
regards,
Jan
Laney in his "Leica Collector's Guide, 2nd. edit. 2005, S. 226 gives the following clue: "...(it has been suggested that for a brief period there was an intermediate design.")
He cites for this on p. 279:
"Nicholson-Johnson, B&A, Viewfinder, 1997, 30, No.1, p32."
Does anybody know this publication?
‘Viewfinder’ is the quarterly journal of the organisation that for the moment at least is still the Leica Historical Society of America (but is likely to drop that ‘H-word’ later this year).
The passage in question reads:
“First, we must consider the curvature of the front element. The Red-scale is slightlv less strongly curved than the regular pre-war type and the early post-war black scale lenses have an identical front element curvature to the prewar version. By around 1950, the front curve became slightly flatter (we have a lens showing this}, but not as flat as the Red-scale.”
Doug Richardson
Viewfinder is a quarterly publication by the Leica Historical Society of America. It is published since 1968 (nº 4 for 2010-Volume 43 was issued in December last) and was co-founded - among others - by James Lager. It is definitely an authoritative publication, and I often rely on my complete collection for references.
