Leica User Forum
Go Back   Leica User Forum > International User Forum > Leica Products > Leica M8 / Leica M8.2
Leica M8 / Leica M8.2 The Leica M8 Forum is dedicated to everything around the Leica M8.
 Leica Products
Leica M silver Leica M-E Leica M Monochrom Leica S LEICA D-LUX 6 LEICA X2
Leica M
» eBay | Adorama | B+H | Dale
Leica M-E
Leica M Monochrom
Leica S
» eBay | B+H | Dale
LEICA D-LUX 6
LEICA X2
Amazon | » eBay | Adorama | B+H | Dale
Old 28/01/13, 20:48   #1 (permalink)
Neuer Benutzer
dblrifle's Avatar
Default SDHC card size
What is the maximum size SDHC card that can be used in an M8?
dblrifle is offline   Reply With Quote
Old 28/01/13, 22:13   #2 (permalink)
Sponsoring Member
wparsonsgisnet's Avatar
Default Re: SDHC card size
I have successfully used at 16gb card (Sandisk). I am now using Panasonic cards, but have not run them in the M8, only in the M9.
I highly recommend the Pana cards; they're just more expensive. They are faster (!) in the M9; again, can't speak to the 8.
Regards, Bill
__________________
Bill Parsons (wparsons@gis.net), Boston
wparsonsgisnet is offline   Reply With Quote
Old 28/01/13, 22:27   #3 (permalink)
Benutzer
Quote:
I have been using this for the past few months without any issues. Write time for RAW is about ~2 seconds (I think).
SanDisk Extreme 32 GB SDHC Class 10 UHS-1
xpr.108 is offline   Reply With Quote
Old 28/01/13, 22:34   #4 (permalink)
Neuer Benutzer
dblrifle's Avatar
Thanks. I should have no problems with the 8GB Sandisk Ultra then. Much appreciated. Manuals aren't very clear.
Old 29/01/13, 05:07   #5 (permalink)
Erfahrener Benutzer
k-hawinkler's Avatar
I did.
__________________
With best regards, K-H.
k-hawinkler is offline   Reply With Quote
Old 29/01/13, 05:14   #6 (permalink)
Erfahrener Benutzer
I use Lexar Professional 8GB 133x speed class 10 card without any problem.
Best
rjans is offline   Reply With Quote
Old 29/01/13, 11:38   #7 (permalink)
wda
Erfahrener Benutzer
wda's Avatar
Quote:
Best
+1
__________________
David
www.davidaskham.com -
(Leica user since ... a very long time ago)
wda is offline   Reply With Quote
Old 29/01/13, 16:26   #8 (permalink)
Erfahrener Benutzer
Quote:
Originally Posted by wda View Post
+1
Me also. And 16 GB 400 speed Lexars.
Sandisk are fine if you buy from a major retailer like B&H, E Bay can have problems with fakes which do not perform to spec. The fakes look very very good.
tobey bilek is online now   Reply With Quote
Old 30/01/13, 00:16   #9 (permalink)
Neuer Benutzer
I have had no problems with 4 and 8 GB cards.
Two summers ago I lost half of Europe trip worth of images that were all on one 16GB card. The card failed. The camera was fine.
But the lesson I learned is to use many smaller cards, rather than fewer big cards. That way, if a failure happens, it will take down fewer images.
chalkdust is offline   Reply With Quote
Old 30/01/13, 19:34   #10 (permalink)
Neuer Benutzer
dblrifle's Avatar
Thank all - I ,also,am a proponent of several smaller rather than one large card. I just felt 8GB was a pretty good compromise ,size and cost. The Sandisk's were purchased at Walmart so hope they are ok. I'm new to Leica digital (go back to 56 on Leica use) and totally new to SDHC cards. My digital to this time has been CF.
Old 31/01/13, 13:36   #11 (permalink)
Erfahrener Benutzer
Default AW: SDHC card size
SDHC specification goes up to 32GB, so that is the maximum size in an M8.
SD cards bigger than 32GB are SDXC specification.
Aviator is offline   Reply With Quote
Old 03/02/13, 05:04   #12 (permalink)
Erfahrener Benutzer
jevidon's Avatar
With the M8, the problem is not the capacity of the card or even the speed of the SDHC cards as I understand it. When I use anything over 8GB, the frame counter reads 999 until I shoot an undetermined number of images; certainly in the hundreds.
Only then does it show a count down. As card consumption goes, the 10mpxl M8 is pretty thrifty due to it's modest mpxl count compared to the other newer cameras on the market.
I have also found that anything faster than around 100x is a waste of money since that transfer rate exceeds the download rate of the camera. So, save your money and stay away from the super high transfer rate, very high capacity more expensive cards.
Any facts to the contrary would be appreciated.
jevidon is offline   Reply With Quote
Old 03/02/13, 08:09   #13 (permalink)
Erfahrener Benutzer
I did find that there was an improvement in buffer time after taking each photo when I changed cards from a memory card that was a Class 4 or 6, to a Class 10 card.
__________________
Leica M8.2
Lax Jought is offline   Reply With Quote
Old 06/02/13, 19:42   #14 (permalink)
Erfahrener Benutzer
Thank all - I ,also,am a proponent of several smaller rather than one large card. I just felt 8GB was a pretty good compromise ,size and cost...
I carry 4 8gb cards along with 2 4gb cards. I think it's best to "spread the wealth" when it comes to my images. I rotate the cards periodically and have never had an issue.
__________________
Best regards,
Bob
CEO-CFO-EIEIO, Ret.
rpsawin is offline   Reply With Quote
Old 06/02/13, 20:27   #15 (permalink)
mjh
Erfahrener Benutzer
mjh's Avatar
Default AW: Re: SDHC card size
Quote:
That’s what every camera with a three digit counter does – since it cannot display a four digit figure it shows ‘999’ until the actual number drops below 999.
__________________
Michael J. Hußmann
mjh is offline   Reply With Quote
Old 07/02/13, 10:31   #16 (permalink)
Neuer Benutzer
Some other cameras with three digit counter can show values higher than 999. The trick is to display e.g "1k2". This is displayed on a Nikon.
Thomas
gyrator is offline   Reply With Quote
Old 09/02/13, 09:28   #17 (permalink)
pop
Moderator
pop's Avatar
Yes, but these counters also will appear to be stuck at a fixed value for some time.
__________________
Philipp
Beiträge in dieser fetten blauen Schrift schreibe ich als Moderator. --
I use this bold blue typeface when I write in my function as a moderator.
pop is offline   Reply With Quote
Old 10/02/13, 07:24   #18 (permalink)
Erfahrener Benutzer
Dougg's Avatar
Perhaps a hexadecimal number readout would be helpful, as there you can get up to the equivalent of 4095 with three digits (FFF).
I've never had as many as 200 shots on a card before off-loading them, so I'm fine with smaller capacity cards.
Dougg is offline   Reply With Quote
Old 11/02/13, 20:48   #19 (permalink)
Sponsoring Member
The speed of the card, in use, may be more important than the largest size.
If you look at:
http://www.l-camera-forum.com/leica-...d-card-issues/
you will see that there are highly rated cards from Panasonic that are very fast in use. They are expensive and this may dictate the purchase: I see the 16GB card at about $70 and the 32GB at $124.
I use 3 of the 16GB card (purchased at a higher price than this, of course, what else is new).
Regards,
__________________
Old 14/02/13, 09:36   #20 (permalink)
Sponsoring Member
cbretteville's Avatar
Default Re: AW: Re: SDHC card size
Quote:
A firmware upgrade to make it read in hex would solve it....
Honestly, I've decided to start using lower capacity cards. 16GB just feels like too many eggs in one basket.
Carl
cbretteville is offline   Reply With Quote
Reply
Bookmarks
Current eBay Ads
Current bid:
510 USD
(12 bids)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0
