CV 12 and 15 mm lenses - image examples please
stevme
I am trying to decide between purchase of the 12 mm CV lens and the 15 mm CV lens.
Would someone be so kind as to post images from each lens? I am trying to get an idea of what the field of view is when used on the M8. I am concerned that the 15 MM lens, which is faster, may not be sufficiently wide enough. I am looking to use the wider lens for interiors and crowd shots. Any other comments about the lenses, including using them with the IR cut filters, would also be appreciated. I have already consulted Sean Reid's reviews.
Thanks
Steve
  • Replies 60
  • Created
  • Last Reply
Here is my take on Montreal with CV 15mm....
More here: Zenfolio | FOTOGRAFIJA | From Montreal, this spring (2007)
Hi,
Here also a 15mm. It comes highly recommended. I am planning on gettng the 12mm as well.
Even though I am living in the Netherlands I order them from CameraQuest Home .
Regards,
Etienne
OK here are 2 shots with the CV 15 on an M8. The exterior of the Time Warner Center is un-manipulated, the interior of the Time Warner Center is a composite of two exposures and adjusted for perspective distortion in PS CS2.
larger versions are here . . .
It's essentially the equivalent of a 20 in 35mm terms.
I've posted this shot previously but here goes again. CV15 on the M8 (Irish brewpub in London). I have both the 12 and 15 and while the 12 may be a touch sharper, it is more difficult to use and physically larger.
Guest guy_mancuso
I will have a bunch next week, spending 4 days shooting only in NY the 12 and WATE will be getting a heavy workout , i will post
I own the CZ viewfinder, but don't use it. Just keep the 12 mounted & let her rip. Crop later.
This has the accessory filter holder (77mm) and a 486 slim line B&W mounted. Here is a storm picture.
I have the LT-M8 adapter coded as a 16mm lens by the way.
Here is photo of Thoroughbred Racing here in KY taken with the 12mm. DR
Here's one with the CV12 ...
And one with the CV15 ...
What viewfinder would you use for the 15mm, and the 12mm lenses?
12 - use a 15 mm finder or the WATE finder set to 16
15 - use a 21 mm finder
I discuss the finder options in some detail in my review of ultra-wide RF lenses.
Cheers,
Sean
