Leica User Forum
Go Back   Leica User Forum > International User Forum > Digital Forum > Leica M8 Forum
090909 Promo
Leica M8 Forum The Leica M8 Forum is dedicated to everything around the Leica M8.
Register now
LinkBack (47) Thread Tools Display Modes
Old 17.01.2007, 22:56   47 links from elsewhere to this Post. Click to view. #1 (permalink)
Erfahrener Benutzer
bradreiman's Avatar
Rotes Gesicht new backfocus thread-solution
Ok-ive been suffering with a bad "backfocus" problem for months. I was scared to adjust myself based on some posts here. Finally yesterday got fed up and took out the 2 mil allen key. Focus to infinity-adjust a bit. Focus to near limit-adjust a bit. Rinse and repeat (3 times). Focus is now spot on. Really easy adjustment. I adjusted with the noctilux so any error would be magnified well. I feel much better now-about the m8, about life in general....b
bradreiman is offline   Reply With Quote
Old 17.01.2007, 23:03   #2 (permalink)
Erfahrener Benutzer
carstenw's Avatar
Default Re: new backfocus thread-solution
How did you adjust it? The near limit adjustment is meant to be behind the red Leica dot...
__________________
Carsten - Photo Blog - Leica M Lens Codes
carstenw is offline   Reply With Quote
Old 17.01.2007, 23:04   #3 (permalink)
Erfahrener Benutzer
Mine is boxed up for NJ as I type for adjustment. I also would love to do this myself, but I didn't find the previous thread to helpful. Can you help me out a bit? Pics or the adjustment parts would be helpful as well.
Great to hear of your success.
Best,
Ron
rondeb is offline   Reply With Quote
Old 17.01.2007, 23:08   #4 (permalink)
Erfahrener Benutzer
bradreiman's Avatar
carsten-i guess i didn't need to adjust the near limit. I just rolled the hex nut in the cam arm back and forth and within minutes near and far limit were spot on. even my 135 2.8 is working now (I thought that lens was out of whack-still is vertically)....b
Old 17.01.2007, 23:09   #5 (permalink)
Erfahrener Benutzer
bradreiman's Avatar
....i suspect the near limit is usually correct and the far limit is what goes out as it has contact with the real world...b
Old 17.01.2007, 23:14   #6 (permalink)
Erfahrener Benutzer
bradreiman's Avatar
ron-there is a 2mil allen key adjustment in the center of the "roller cam" in the lens mount. i just set the lens to infinity-look at a vertical on the horizon-take lens off and turn the allen key a bit-lens back on to check infinity-rinse and repeat-then fine tun a bit at near and mid focus...b
Old 17.01.2007, 23:41   #7 (permalink)
Erfahrener Benutzer
Can someone take a picture so we can have a better idea what this means?
gesper is offline   Reply With Quote
Old 18.01.2007, 01:19   #8 (permalink)
Benutzer
Quote:
interesting test, bradley, and thanks for sharing with us. one thing i don't understand, however, is why you need to readjust at different focus points. i thought the cam always sprung back to same position when a lens is removed, no matter what the focus. as such, the adjustment will impact all focus distances the same, or am i missing something?
john
jcbjr is offline   Reply With Quote
Old 18.01.2007, 02:28   #9 (permalink)
Benutzer
well, i was a bit skeptical it would work, but just tried it and it worked perfectly. just as bradley suggested, use a 2mm allen wrench. remove lens, insert short end of wrench into round silver cam at top of camera body opening. with camera laying flat on surface facing you, long end of wrench pointing straight out from camera body, gently place finger behind cam to hold it in place (it's spring loaded). for back-focus, gently rotate wrench to the right (away from m8 logo), just a few degrees. i think mine required about two or three degrees. voila! perfect focus using nocti @ f1.0, short and medium distance (couldn't do infinity as it's night here). good work, bradley! saves a trip to nj or possible solms!
john
Old 18.01.2007, 02:37   #10 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Quote:
Carsten:
The vertical alignment of the rangefinder is behind the Red dot.
The near focus limit is at the fulcrum of the arm that the focus roller is on. I just looked at my M7 and it doesn't look like anything you want to play around with as it is in quite close quarters.
Brad is correct, the near is seldom off. If you get the infinity right it will usually cure focus problems.
Robert
robsteve is offline   Reply With Quote
Old 18.01.2007, 06:29   #11 (permalink)
Erfahrener Benutzer
bradreiman's Avatar
Quote:
john
Hi John-I really only did middle to check. Near and max distances seem to do the trick and what a piece of cake to do. I've been out with the noctilux all day since I can finally use it.
Old 18.01.2007, 07:02   #12 (permalink)
Erfahrener Benutzer
Drat, Brad!
I was biding my time waiting for you to get so frustrated with the lens that you'd accept an offer of $1000.
Seriously, glad you got it going!
--HC
ho_co is online now   Reply With Quote
Old 18.01.2007, 07:51   #13 (permalink)
Erfahrener Benutzer
carstenw's Avatar
What does fulcrum mean in this context: shoulder or elbow (given that the arm has two links)?
Mine needs a near-focus adjustment badly. I have adjusted the infinity which is bang on, but near focus is off by several centimeters at short distances. It is also slightly vertically out. My camera is the one which Leica forgot to adjust, and two times at that.
__________________
Old 18.01.2007, 10:18   #14 (permalink)
Erfahrener Benutzer
pascal_meheut's Avatar
Same experience as Bradley Reiman, same results. Focusing precision with the 75mm af f/2 and short distance is incredible.
pascal_meheut is online now   Reply With Quote
Old 18.01.2007, 11:45   #15 (permalink)
Erfahrener Benutzer
Default AW: Re: new backfocus thread-solution
Carsten,
in my case its more aproblem of lenses and not the camera.
Some lensesspot on (at short and long distance (i.e. 75/1.4, 90/2.8,35/!.4), others are off at short distance (Noctilux, 50/1.4asph, 135/3.4)
I will send those lenses in to Leica.
I also will send samples images and a letter with the lenses to clearly describe the problem.
I once sent my 35/1.4 to Leica for focus adjustment and now its spot on.
cheers,Tom
tom0511 is offline   Reply With Quote
Old 18.01.2007, 15:39   #16 (permalink)
Erfahrener Benutzer
robsteve's Avatar
Carsten:
The adjustment is at the pivot point of the arm, where it attaches to the rangefinder. You loosen the screw and move an eccentric. I wouldn't play with it as it may not be easy to set up. Leica uses a jig for these settings.
Robert
Old 18.01.2007, 18:58   #17 (permalink)
Neuer Benutzer
Thank you for all these solutions but it would be really better to have some pictures to illustrate all these adjustments... I'm afraid to make a big mistake
fredbonhomme is offline   Reply With Quote
Old 18.01.2007, 19:36   #18 (permalink)
Erfahrener Benutzer
Thanks for the tip. I just tried this and there is definitely improvement. Although now I discovered that my 28mm front focuses...
__________________
John
johnkuo is offline   Reply With Quote
Old 18.01.2007, 21:27   #19 (permalink)
Erfahrener Benutzer
Here are the pictures. You just put your 2mm Allen wrench where the red arrow is, as shown in the 2nd picture and your turn slowly, 1/10th of a turn or less being careful not using excessive force and just rotating, not pressing in any direction.
If you do not have an infinite point to adjust, you can try by shooting some books on a shelf, each at a difference distance. After adjusting, you mount a long lens wide-open, you focus precisely and you check on the screen where your focus point is.
Once you are in focus, check that you are in the DOF range, not at the end of it.
You can also use a special target. See http://www.leica-camera-user.com/dig...cus#post131553
Old 18.01.2007, 21:34   #20 (permalink)
Neuer Benutzer
Merci Pascal
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/13933-new-backfocus-thread-solution.html
Posted By For Type Date
Leica m8: primeras imagenes - Página 72 - OJODIGITAL This thread Refback 18.12.2009 18:59
[Leica] Noctilux f1 images This thread Refback 01.12.2009 19:57
Leica M8 backfocus | Lightstalkers This thread Refback 23.11.2009 18:47
Front focus, 50mm f/1.4 on Flickr - Photo Sharing! This thread Refback 23.11.2009 05:36
m8 primeras imagenes • Ver Tema - Telémetro desalineado. This thread Refback 04.11.2009 20:12
m8 primeras imagenes • Ver Tema - Telémetro desalineado. This thread Refback 04.11.2009 09:23
m8 primeras imagenes • Ver Tema - Telémetro desalineado. This thread Refback 04.11.2009 01:56
I finally adjusted my M8 for back focus. - ClubSNAP Photography Forums This thread Refback 11.05.2009 03:08
I finally adjusted my M8 for back focus. - ClubSNAP Photography Forums This thread Refback 10.05.2009 20:09
I finally adjusted my M8 for back focus. - ClubSNAP Photography Forums This thread Refback 10.05.2009 19:35
L E I C A P A S S I O N F O R U M :: Leggi argomento - Ho comprato la brugola ma... This thread Refback 01.05.2009 22:43
Operated on my M8 today...: Leica Talk Forum: Digital Photography Review This thread Refback 30.04.2009 06:09
Operated on my M8 today...: Leica Talk Forum: Digital Photography Review This thread Refback 30.04.2009 02:41
Operated on my M8 today...: Leica Talk Forum: Digital Photography Review This thread Refback 30.04.2009 00:29
Operated on my M8 today...: Leica Talk Forum: Digital Photography Review This thread Refback 30.04.2009 00:25
Canon LTM50 F1.2 issues - ClubSNAP Photography Forums This thread Refback 13.04.2009 14:24
Canon LTM50 F1.2 issues - ClubSNAP Photography Forums This thread Refback 13.04.2009 13:26
Canon LTM50 F1.2 issues - ClubSNAP Photography Forums This thread Refback 13.04.2009 13:12
What size allen key to adjust M8 backfocus - Rangefinderforum.com This thread Refback 27.03.2009 17:11
:: - M8 This thread Refback 27.01.2009 13:09
:: - M8 This thread Refback 27.01.2009 07:31
:: - M8 This thread Refback 27.01.2009 07:09
Focus shift with Canon 50mm 1.2 and M8 - Rangefinderforum.com This thread Refback 15.12.2008 01:27
Focus shift with Canon 50mm 1.2 and M8 - Rangefinderforum.com This thread Refback 01.12.2008 13:26
Focus shift with Canon 50mm 1.2 and M8 - Rangefinderforum.com This thread Refback 01.12.2008 09:50
Focus shift with Canon 50mm 1.2 and M8 - Rangefinderforum.com This thread Refback 01.12.2008 03:42
[Leica] Noctilux f1 images This thread Refback 04.10.2008 00:17
Leica m8: primeras imagenes - Pgina 179 - Foro de fotografa - OJODIGITAL This thread Pingback 17.08.2008 13:17
Testing rangefinder accuracy on M8 body - Photo.net Leica and Rangefinders Forum This thread Refback 05.08.2008 14:02
Leica M8 woes !! - ClubSNAP Photography Forums This thread Refback 01.08.2008 04:18
Leica M8 woes !! - ClubSNAP Photography Forums This thread Refback 01.08.2008 03:58
Leica M8 woes !! - ClubSNAP Photography Forums This thread Refback 01.08.2008 03:53
Leica M8 woes !! - ClubSNAP Photography Forums This thread Refback 01.08.2008 03:45
What size allen key to adjust M8 backfocus - Rangefinderforum.com This thread Refback 13.07.2008 20:10
What size allen key to adjust M8 backfocus - Rangefinderforum.com This thread Refback 14.06.2008 22:57
What size allen key to adjust M8 backfocus - Rangefinderforum.com This thread Refback 13.06.2008 19:03
What size allen key to adjust M8 backfocus - Rangefinderforum.com This thread Refback 13.06.2008 18:58
What size allen key to adjust M8 backfocus - Rangefinderforum.com This thread Refback 13.06.2008 18:54
[Leica] Noctilux f1 images This thread Refback 08.05.2008 20:17
[Leica] Noctilux f1 images This thread Refback 22.04.2008 02:47
[Leica] Noctilux DOF Film vs M8 This thread Refback 21.04.2008 06:31
[Leica] Noctilux DOF Film vs M8 This thread Refback 20.04.2008 23:46
Leica M8 backfocus | Lightstalkers This thread Refback 28.11.2007 19:07
Backfocus - M8 or lens or both: Leica Talk Forum: Digital Photography Review This thread Refback 27.08.2007 18:07
Re: Backfocus - M8 or lens or both: Leica Talk Forum: Digital Photography Review This thread Refback 27.08.2007 18:00
Leica and Rangefinders Forum: Testing rangefinder accuracy on M8 body - photo.net This thread Refback 15.07.2007 22:48
Leica and Rangefinders Forum: Testing rangefinder accuracy on M8 body - photo.net This thread Refback 15.07.2007 21:10
Similar Threads
Thread Thread Starter Forum Replies Last Post
New banding issue comment jrc Digital Forum 17 18.12.2006 12:23
LEICA ANNOUNCEMENT: New Leica Digital Cameras daniel Digital Forum 46 22.11.2006 20:01
SAMYs LA and buying Leica gear new. bradreiman Digital Forum 9 22.10.2006 01:01
LEICA ANNOUNCEMENT: New Leica Products - LEICA M8 / M System daniel Digital Forum 199 01.10.2006 16:18
new LIGHTROOM 4 vic vic Digital Forum 1 27.09.2006 11:07
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
